Metal bluing parts of the lathe
Home › Forums › General Questions › Metal bluing parts of the lathe
Viewing 25 posts - 1 through 25 (of 38 total)
  • #24953
    Gareth T
      @garetht
      #273231
      Gareth T
        @garetht
        Hi all,
        I am in the progress of rebuilding a Colchester Student mk2. I am thinking about bluing some of the metal such as the tool post and other bits, they all had light surface rust and are currently in an oil bath after rust removal and I was thinking of oil bluing some of the parts to give them some rust protection.
        What are your thoughts for and against doing this please?
        #273232
        Mike Poole
          @mikepoole82104
          If it is a Dickson tool post I would be disinclined to heat it again after it has been finish ground.
          #273237
          Roderick Jenkins
            @roderickjenkins93242
            Probably best to bear in mind that oil bluing means heating the item up to temperatures in excess of those used for tempering carbon steel, so if the pieces have been hardened they will soften. You might be better of using a blacking solution such as this.
            HTH,
            Rod
            #273240
            Gareth T
              @garetht
              Posted by Roderick Jenkins on 22/12/2016 09:46:18:
              HTH,
              Rod
              I like the idea of the cold blue a lot better
              #273242
                @mike89748
                You can buy cold blacking and blueing solutions from almost any gun shop. The secret is thorough de-greasing (including finger prints), then follow the instructions to the letter. Experience indicates that most are good on small components (in gun terms, things like trigger guards and top levers) but if used on large areas the finish can be blotchy.
                #273244
                KWIL
                  @kwil
                  You will also find that items subject to handling will eventually loose their "blacking", good for cosmetic use but a lightly oiled item will probably be just as good.
                  #273247
                  Chris Evans 6
                    @chrisevans6
                    One tool room I worked in specialised in small mainly form ground injection moulds. They would "Black" some items on the tool to give a nice contrast to the ground finishes. A great sales aid from presentation as a few customers thought they where getting special coatings on the tool to enhance tool life.
                    #273252
                    Nick Hulme
                      @nickhulme30114
                      Posted by Mike on 22/12/2016 10:00:34:
                      The finish is also less durable than the "Hot Caustic" process, it's easy to google Hot Caustic Blacking, I'll not post a recipe here as it's "Scary" for the H&S obsessed and will avoid the usual wailing and moaning
                      – Nick
                      #273261
                      pgk pgk
                        @pgkpgk17461
                        Would it be daft to suggest ordinary stove blacking? Gives a nice clean finish once polished in and easy to re-apply.
                        #273263
                          @mike89748
                          pgk you're ahead of me – I was just Googling for black metal finishes, and came across some stuff called Stovax Colloidal Black. Never tried it, but it reminds me of some stuff called Zeebo my grannie used on her kitchen range.
                          #273265
                          pgk pgk
                            @pgkpgk17461
                            I just bought a tube of whatever they had in the local hardware shop.. everyone has wood burners and old stoves in this backwater part of wales
                            #273267
                            Roderick Jenkins
                              Am I not right in thinking that stove blacking is just graphite powder in some sort of carrier? I understand how it works on the porous surface of cast iron but would be surprised if it would stick to ground or machined steel; especially if it is receiving regular handling.
                              Cheers,
                              Rod
                              #273269
                              Trevor Drabble 1
                                @trevordrabble1
                                Gareth , As an alternative may I suggest you consider a company called BLACK-IT on http://www.black-it.co.uk and 01758 730356 . I have no connection with the company .
                                Trevor .
                                #273276
                                Harry Wilkes
                                  @harrywilkes58467
                                  Ok this requires some heat but worth taking a look link
                                  Merry Christmas to All
                                  H
                                  #273280
                                  Saxalby
                                    @saxalby
                                    I have used the cold blacking from http://www.black-it.co.uk on the bare steel parts of my Boxfords and my tool grinder (ball handles and the like) and while not as durable as hot blacking it is still quite durable. Did mine a couple of years ago and only now are some handles showing signs of the black fading. And it certainly helps to stop rust forming.
                                    Surfaces must be TOTALLY degreased for the blacking to work.
                                    Regards Barry
                                    #273283
                                      @mike89748
                                      Harry, this looks like oil blacking, which does work on steel. Motor oil doesn't seem to work very well, probably because of its composition these days. I've oil blacked lots of gun screws, and have found cheap supermarket own-brand margarine to be very effective, although it does make the workshop smell like a fire in a chip shop!
                                      #273284
                                      Douglas Johnston
                                        @douglasjohnston98463
                                        Rapeseed oil (cooking oil from the supermarket ) works well for heat blacking, but not a good idea for hardened objects.
                                        Doug
                                        #273286
                                        Russell Eberhardt
                                          @russelleberhardt48058
                                          When at school in about 1960 we were made to rub a few drops of oil into our hands on entering the metalwork shop. I still do that and have very little problem with rust. A thin film of oil on your toolpost should be all that's needed.
                                          Russell.
                                          #273288
                                          Emgee
                                            @emgee
                                            Posted by Douglas Johnston on 22/12/2016 14:31:33:
                                            Rapeseed oil (cooking oil from the supermarket ) works well for heat blacking, but not a good idea for hardened objects. ..
                                            Douglas, do you mean use rapeseed oil for quenching the heated part ?
                                            Emgee
                                            #273289
                                            Bob Rodgerson
                                              @bobrodgerson97362
                                              Russel, I rub Barrier Cream into my hands and don't have a rust problem either.
                                              #273304
                                              Hacksaw
                                                @hacksaw
                                                My mate gave me a Dixon QC but it was too tall for my S&B model M , and on putting it in my his bandsaw to whip a bit off the bottom , obviously it bounced the blade off !!
                                                So in the gas forge it went .. 10 minutes and its a nice yellow and scale forming..slow cooling…and still it bounced the blade ! Carbide mill got it shortened up , i never bothered to re harden it again .
                                                #273310
                                                Gareth T
                                                  @garetht
                                                  Some great advice guys, I am going to powder coat some bits, cold blue other bits and oil the rest that i cannot repaint.
                                                  #273336
                                                  Harry Wilkes
                                                    @harrywilkes58467
                                                    Posted by Mike on 22/12/2016 14:21:28:
                                                    Mike like the sound of the chip shop but not the fire bit wink
                                                    H
                                                    #273344
                                                    David Standing 1
                                                      @davidstanding1
                                                      Posted by Russell Eberhardt on 22/12/2016 15:08:55:
                                                      Russell.
                                                      I've never used either oil OR barrier cream on my hands, and in 62 years I can truthfully say they have never rusted smile p
