Thread cutting and Change gears
Home › Forums › General Questions › Thread cutting and Change gears
  • #219484
    Roger Hulett
      @rogerhulett83124
      I have a S.B. 9" and I am about to commence some screw thread cutting. I find that some of my change gears are duplicated.I have studied the SB screw cutting chart and there is no indication that I would ever need to use two similar gears at the same time.
      My question is….Should I keep the duplicates or should I sell them or should I try to swap them with someone for gears that I do not have (and may well never use) ?????
      #24304
      Roger Hulett
        @rogerhulett83124
        #219485
        Ralph H
          @ralphh
          Duplicated changewheels do have a use but I am not sure enough how myself. I am sure that someone on here will know.
          #219502
          Jon Gibbs
            @jongibbs59756
            If they're duplicates of either the smallest or the largest gears then they can be useful for setting up very slow feed rates.
            HTH
            Jon
            #219508
            Martin Connelly
              @martinconnelly55370
              They can be used as idlers. Idler gears can be any size but they need to be a size that allows a set-up. If you have pre-owned lathe then there is a possibility you do not have a full set of gears and the duplicates can be used instead of idlers listed on a change gear chart that are missing from what you have.
              Martin
              #219511
              wheeltapper
                @wheeltapper
                Hi
                this little program may help you. **LINK**
                you input all the gears you have ( including doubles), input your leadscrew pitch and the thread you want to cut and it churns out a list of possible gear setups.
                I use it all the time because my lathe has a chart on which some of the setups only work in theory.
                Roy.
                #219520
                Roger Hulett
                  @rogerhulett83124
                  Thanks everyone. The screwcutting program is excellent.
                  #219563
                  Bodger Brian
                    @bodgerbrian
                    Posted by wheeltapper on 05/01/2016 14:44:05:
                    Hi
                    Although the link itself works, there is a link within that page to a diagram of a typical change wheel setup (gear-train.bmp) that appears to be broken. Can anyone point me in the direction of any other link/diagram that shows the same thing?
                    Brian
                    #219568
                    John Stevenson 1
                      @johnstevenson1
                      How about this one specifically for the Myford ?
                      Speedy Builder5
                        @speedybuilder5
                        Remember, you can't cut all threads using the std gear range and have to sometimes create your own ratios, approximating within 1 tip or so. Especially BA threads !! Keep the gears.
                        BobH Boxford AUD (similar to the SB 9)
                        #219571
                        Bodger Brian
                          @bodgerbrian
                          Posted by John Stevenson on 05/01/2016 20:49:35:
                          Thanks John – looks as if that might be what I'm looking for. Presumably the general principle applies to lathes in general & not just Myfords?
                          Brian
