Flame Hardening
Flame Hardening
Home Forums General Questions Flame Hardening
  • #23720
    stan pearson 1
      @stanpearson1
      #179909
      stan pearson 1
        @stanpearson1
        Hi
        Does any body know anything about Flame Hardening mild steel if so how good is it for small parts of valve gear on 5"g models.
        Stan
        #179914
        Nobby
          @nobby
          Hi Stan
          You can only case harden mild steel .
          Nobby
          #179952
          JohnF
            @johnf59703
            Stan, you can flame harden with oxy acetylene using a carburising flame but the skin is very thin, a few microns. Set the flame to oxygen week I.e. With a long centre cone, this means the carbon fuel gas is not being fully consumed thus an excess of carbon in the flame, heat the part and keep at bright cherry red for a while, several mins, then quench in water. Might work with oxy propane but never tried this . The surface will be toughened rather than glass hard but nevertheless more wear resistant.
            Not a very efficient way to harden and as I said the surface is VERY thin, best way is as Nobby says to case harden with Kasnit or similar.
            I know nothing of steam valves but if you want them hardened why not make them of a suitable hardening steel, EN8 or EN9 the latter hardens easier and harder but you will need to temper them as well.
            Regards John
            #180001
            mick
              @mick65121
              For a short while I worked for a blacksmith and he showed me how to case hardening with acetylene. You start of with no oxygen at all, which coats the steel in black soot, then you use oxygen to heat the steel to red heat, then a repeat coating of the soot and heat to red. Do this tree or four times, then quench after the last heating. Seems that the soot is pure carbon and the heating soaks into the surface. Useful to know, but I always use Kasnit!!!
              #180008
              JohnF
                @johnf59703
                Mick, more or less same thing, I was shown to use a small amount of oxygen which in turn does depost soot on the work. I'll try your method next time I have occasion to do something but in either case the hardened surface wil be extremely thin.
                #180034
                stan pearson 1
                  @stanpearson1
                  Hi
                  Thank you all for your reply when I served my time in the late 50s we had a blacksmith who gave us a file to drill a hole in alongside his already drilled hole. After several attempts and several blunted drills he showed us how it was done, he heated to red and buried it in a box of Lime for a couple of days after that he drilled a hole re heated and buried it in a box of soot and it became a file again. I think I will use a hardening compound as suggested but I don't think you can still buy Kasnit !
                  Thanks again Stan
                  #180063
                  mechman48
                    @mechman48
                    Stan…
                    ….but I don't think you can still buy Kasnit… check this out
                    George
                    #180074
                    KWIL
                      @kwil
                      Not genuine USA Kasenit, somebody has just left a metatag so that your search ends on their ad! I thought genuine Kasenit was no longer made or available.
                      #180135
                      stan pearson 1
                        @stanpearson1
                        Hi All
                        No I bought some of that Beta 1 from EBay but it didn't work for me but I don't think Kasenit is made any more because the EU banned it for containing Arsenic I think
                        Stan
                        #180139
                          For reference: The archived MSDS for Kasenit can be found here.
                          … It's probably the Cyanide that worried the EU.
                          Ian S C
                            @iansc
                            Although I believe that Kasenit claims that the Cyanide as used in their compounds is non toxic, I'v still got about half a tin of it, had that for around 20 years, so at that rate it might see me out.
                            Ian S C
                            #180195
                            JA
                              @ja
                              The subject of cyanide in Kasenit (and probably other case hardening compounds) has been dealt with here before.
                              The cyanide is probably Potassium Ferricyanide which gives up its carbon to be absorbed into the steel along with the carbon already present in the case hardening compound. By itself Potassium Ferricyanide is not toxic but will produce hydrogen cyanide, very poisonous, with a strong acid.
                              The label on later Kasenit tins, such as the one on my shelf, clearly states that product is "non-poisonous".
                              JA
                              Edited By JA on 18/02/2015 10:40:30
                              Edited By JA on 18/02/2015 10:41:20
                              #180200
                                Posted by JA on 18/02/2015 10:38:29:
                                The cyanide is probably Potassium Ferricyanide …
                                For what it's worth [?]
                                The MSDS states the ingredient to be Sodium Ferrocyanide
                                Edit: and apparently, that's a food additive !!
                                Do we have a Chemist who could advise ?
                                Edited By Michael Gilligan on 18/02/2015 11:28:03
                                #180202
                                David Jupp
                                  @davidjupp51506
                                  The MSDS mentions evolution of trace HCN in use and makes recommendations regarding ventilation.
                                  #180213
                                    It's all down to quantity. Heat up a spoonful of sodium ferrocyanide and it will give off a small amount of cyanide and carbon monoxide. Heat up a spoonful of table salt and I suspect the amount given off will be comparable to what you get from eating a cherry.
