Rivet sets & snaps
Rivet sets & snaps
Home Forums General Questions Rivet sets & snaps
  • #108111
    RRMBK
      @rrmbk
      Can anyone please point me in the direction of the correct dimensions for the hole in first stage rivet setting tooling as opposed to the domed snap tool for finishing rivets; and the amount of rivet projection required for tidy doming ..
      I am having great trouble getting decent finished domes and I think its beacuse I am
      A not getting the correct amount of material projecting and
      B not using suitable setting tools.
      Many thanks
      Brian K.
      RRMBK
        @rrmbk
        #108112
        MadMike
          @madmike
          Brian the form and size of the dome that you want to create is dictated by the grip length, the final closed length between heads, and the diameter of the rivet itself. The easiest way to get the right size is to refer to copy of Machinery's handbook or similar tome which will have tables to help. You may need to extrapolate and then experiment to get the final size right.
          #108113
          HomeUse
            @homeuse
            Hi this site may help – I have always found it produces good domes – **LINK**
            #108115
              Teh hole in the set is not that important, just a bit bigger than the rivit shank so something like 3.3mm on an 1/8" rivit, 4.8mm on 3/16" and so on.
              The amount projecting is slightly affected buy your snap as they do vary a bit but the correct projection for imperial snap head rivits is 1.429xD, treat this as a starting point and do a few tests in a scrap of known thickness and then adjust the lengths to sue whatever thicknesses of material are being joined
              Sapphire Have a useful table of sizes for all their rivits
              #108141
              alan-lloyd
                @alan-lloyd
                AHi Brian, invest in an arrand rivet shortner, this cuts the rivets off straight, un like a pair of pliers. You can then experiment with the head length because you have to make spacers to suit each dia, so every one you do in future will be the same. marvelous tool. Regards Alan.
                #108171
                  The OP may be looking at some classic texts which show, after closing, an upsetting tool with a limitted depth hole being used to cause the trunk of the rivet to swell prior to being domed out with a shaped snap. Trouble is it doesn't work with cold rivets as they are too hard to deform like that. (Similar to a blacksmith 'upsetting' a bar by hammering the end not the side to cause a swelling at the part that has been heated)
                  #108174
                  Terryd
                    @terryd72465
                    Posted by Brian Kerens on 07/01/2013 11:33:59:
                    I am having great trouble getting decent finished domes………………..
                    Many thanks
                    Brian K.
                    Hi Brian,
                    are you rough forming the dome with a ball peen hammer before using the snap?
                    Terry
                    #108179
                    Springbok
                      @springbok
                      The Arrand tool is great will crop anything
                      Bob
                      #108184
                      HomeUse
                        @homeuse
                        Hi – can anyone give me a link ore details of this Arrand tool – seems i must have missed it
                        #108217
                        Robert Dodds
                          @robertdodds43397
                          Home use,
                          Springbok put some pics of his and phone details to Arrand on this forum under "Rivet Set Dimensions" just 12 months back.
                          Bob D
                          #108268
                          HomeUse
                            @homeuse
                            Thanks Bob D – will look up details.
                            #108270
                            RRMBK
                              @rrmbk
                              Thanks all for the responses Gents. I have been using the 1.5/1.6 dimension for length, and annealing rivets before using them.
                              – Bazyle – very interested in your comment that the initial setting process isnt viable. Jason B am I right in assuming you Do use the setting process and does it work for you?
                              Terryd – I use ball peen for csk finish on rivets but hadn't considered it for RH. I see the logic and if I understand it you use the snap just to form the final dome shape rather than the whole rivet closing process.
                              Thanks again all
                              B K
                              #108272
                              Terryd
                                @terryd72465
                                Hi Brian,
                                the standard method for domed rivets is to set the joint, form the dome with the ball peen and then final finish is with the domed set. If you try to shape the rivet solely with the set the rivet will bend and produce a very poor finish. Soft iron rivets should need no annealing.
                                I have always used the 1.6 x dia for the dome allowance plus the required length, this gave good results. There was a good article which included advice for rivetting just a couple of years ago. I will look out the reference.
                                Peening a rivet
                                Best regards
                                Terry
                                #108279
                                  Brian, I use the set to push the layers together, this does not start to compress the rivit and then unlike Terry I go straight at it with the rivit snap and a few blows are all that is needed.
                                  The ball pein is ok if you are working with a rivit in a nice flat accessible position but once you have formed a couple of hundred rivits on traction engine wheels where you can't get in with the hammer you soon get the knack of only using a snap. The other risk of using teh ball pein is that if you take a lot of little taps at the rivit you can start to work harden the end which makes it harder to form the final snap.
                                  I have seen the staged formers used on cold rivits with good results usually in conjunction with a jig to hole the formers upright and a hydralic press. Not really needed on anything below 3/16" though. I'll see if I can find some pictures, the ones I know of are only viewable if you donate to teh particular forum.
                                  I also cut mine with either mini bolt croppers or side cutters
                                  Couple of bits of riviting here and here
                                  Edited By JasonB on 09/01/2013 13:20:44
                                  #108280
                                    Just looked for the phoyo but they will not be available, If anyone has Edward George's (Martin Wallis in ME) book he has a couple of pages detailing forming the rivit in 4 stages
                                    Set
                                    Flat ended tool to inittialy spread the rivit
                                    Cone ended tool to get a good spread at the bottom
                                    Snap to form teh final snap head
                                    This is what he used on his 1/2 scale Fowler with just a club hammer and a pair of ear defenders.
                                    Talking of riviting people may find some pics from the restoration of a portable of interest though unfortunately the riviting method may not suite the average home workshop.
                                    Springbok
                                      @springbok
                                      Arrand
                                      The Forge
                                      Knossington Nr Oakham
                                      LE15 8LN
                                      0116454566
                                      I bought mine in 2006
                                      I not only use it for cropping rivets but bolts wire you name it.
                                      Have a look at my my photos near the bottom you wil see a pic of it I took for someone else.
                                      They did not have a web site at the time but that may have changed
                                      Part Number 67-100
                                      Bob
