Chris,
I have a couple of plasma cutters, hand held jobbies. One is a large Cebora that can cut 16mm plate and sever 20mm but it's very heavy to run, I reckon I can get more heat off the gimbal of the electric meter than the torch !
, but it's good.
To that effect I recently bought one f these cheap Cut 40 inverter plasma that run off a three pin plug.
Will cut 6mm and sever 8mm but they really come into thier own around 3mm and "if" the torch control is good enough the finish is equal to laser.
Couple of weeks ago i had some 10" circles to cut out of the front of some control panels, I useually do it with a jig saw and clean up afterwards, a fiddly job.
As an experiment I bolted a lump of angleto the bed of the CNC mill sticking out 3 foot from one end, a simple clamp for the torch was made and a push button replace the button on the torch, simple job as it's got it's own lead.
Then programmed a circle at 10 1/8" to allow for cut off set, started just inside and did a lead in, lead out and the cut was absolutely perfect, just a bit of dross to chip off the underside.
Definitely a method to use for other jobs as it was so simple to impliment and use. I used a 25 gallon drum as the cutting table which is ideal given the hight of the mill.
John S.
