I have a Super 7 and have recently purchased a dividing head. I plan to use it for milling octagons using the non-swivelling vertical milling slide (probably overkill to use a dividing head, but hey!). I therefore have the milling head axis at right angles to the lathe axis. However, I'm finding that the cross slide needs to be wound out a long way to bring the milling cutter anywhere near the workpiece, held in an ER20 collet in the dividing head, as the vertical milling slide does not fit the T-slot in front of the top-slide hold.
So… my question is, do I need to purchase the (expensive) milling slide raising block, or is there another way?
Many thanks,
