Wall Storage Recommendation
Home Forums Workshop Tools and Tooling Wall Storage Recommendation
Viewing 25 posts - 1 through 25 (of 38 total)
  • #387147
    Rob Manley
      @robmanley79788
      I'm asking the ME collective for a recommendation as my searches haven't found anything I would trust.
      A casualty of my workshop move was my donated wall mounted storage unit, that contained taps, dies, reamers, screws etc, weighed a ton when fully loaded and was just about big enough. The plastic drawers have started to crack with age and being overloaded.
      So, I am after a suitable replacement. I would like to have around 28 drawers of 4"x3"x6" and be wall mounted. My previous one was a sheet metal unit but I'm open to suggestions.
      Thanks all, Rob.
      #19175
      Rob Manley
        @robmanley79788
        #387152
        Dalboy
          @dalboy
          Have you considered making one from wood that way you can make it whatever size you want. It would not be difficult to construct.
          #387159
          Robert Atkinson 2
            @robertatkinson2
            I'm a big fan of Really Useful Boxes. They are available in a wide range of sizes. They stack neatly so shelves with 2 or 3 stacked on each and the occasional full depth vertical "divider" to the floor or extra shelf support on the bottom shelf to stop sagging if you have heavy contents.
            http://www.reallyusefulproducts.co.uk/uk/html/onlineshop/fullrange_rub.php
            They are tough (you can stand on small one or corner of a large one) and while not sealled (a good thing in my mind) they keep dust and dirt out. Not completely clear but easy to identify most contents.
            Robert G8RPI.
            #387162
            Ian Parkin
              @ianparkin39383
              Bisley *. multidrawer filing cabinets 15 drawer ones I use
              I have about 20 of these scattered around
              you can get them for about £20 upwards depending on condition
              Ian
              * other brands available
              Edited By Ian Parkin on 22/12/2018 19:51:50
              #387173
              JC54
                @jc54
                I often see Bisley at autojumbles I bought a couple for £10.00 each a couple of years ago. Well made and take some "hammer".
                #387175
                Chris Evans 6
                  @chrisevans6
                  Plus 1 for Bisley
                  #387185
                  Ady1
                    @ady1
                    For strength and compactness, Bisley
                    You can also pull a drawer right out, giving you a metal tray for inspecting bits or moving to another Bisley unit
                    Comes in 5 10 15 up to 30 drawers
                    #387190
                    Pete Rimmer
                      @peterimmer30576
                      I also use the Bisley drawer units. For taps, dies and fasteners etc I use home made drawer dividers. I had some strips of 18 or 20g steel cut about 45mm wide, then cut them into sections some equal to the drawer inside length and some to the width. Then I just decide how many dividers I want in a particular drawer and use a mini-grinder with a 1mm disc to cut notches half way across each divider at the appropriate centres. You just slot the short ones into the long ones to make a grid in the drawer.
                      #387204
                      thaiguzzi
                        @thaiguzzi
                        Posted by Chris Evans 6 on 22/12/2018 21:35:57:
                        Plus 1 for Bisley
                        Make that +2 for Bisley.
                        #387217
                        Mike Poole
                          @mikepoole82104
                          **LINK**Have a look at these units they seem close to your spec.
                          #387245
                          Ady1
                            @ady1
                            A look at a single drawer
                            Spanners 20 to 32mm go longways
                            under 20mm widthways
                            #387254
                            Pete Rimmer
                              @peterimmer30576
                              Here are the dividers I make for Bisley drawers, as described above. Simple to make and very effective:
                              Edited By Pete Rimmer on 23/12/2018 11:53:25
                              #387269
                                Unless you have a heated and dehumidified workshop metal boxes spell rust both for them and the tools. I would suggest adjustable shelves to allow adaptation and various plastic food boxes.
                                I don't know where people are finding Bisleys at sensible prices. I've only ever been able to afford a small one and it lives in the study so I know it and it's contents stay dry.
                                #387273
                                Vic
                                  @vic
                                  I used Bisley drawers at one time but due to the construction it’s inevitable that the bottom of the drawers will go rusty unless you have a completely dry workshop. I’ve had a couple of garage workshops so the bisley drawers eventually went to the dump when some of the tools in them displayed signs of rust. I instead invested in a variety of sizes of clip lock food containers. These keep tools dry in even the most damp conditions. I did put anti rust paper in some just in case but this has proved not to be necessary. These containers are stored in a couple of multi shelf steel cabinets I bought from Ikea. Small tools can represent a large investment so nobody wants them to go rusty and can you be sure that they will always be kept in a damp free environment?
                                  #387274
                                  Vic
                                    @vic
                                    These are the cabinets I bought from Ikea. They come with lots of shelves which I lined with thin MDF to prevent scratching.
                                    mechman48
                                      @mechman48
                                      +3 for Bisley drawers; I bought a 15 drawer one from an auction house for £20…
                                      I have a couple of sheet metal storage drawers for a miscellany of tools but I am in the process of changing them for plastic hobby/ fisherman's / food storage type containers to alleviate as far as possible the onset of rust. I have anti rust paper in my roller tool cabinet drawers; ( plus will be placed in the Bisley drawers ), which have proved a boon, plus a couple of small oil heaters to keep the garage/workshop warm.
                                      #387277
                                        Posted by Bazyle on 23/12/2018 12:35:07:
                                        I don't know where people are finding Bisleys …
                                        Used to be dead common second-hand round here – and cheap. Not so nowadays. I think a lot of offices dumped their Bisleys over a 30 year period as computers took over and that source has dried up now.
                                        Might be a regional thing, but after a long search I had to buy a new one!
                                        Pete Rimmer
                                          @peterimmer30576
                                          There is a third option – good insulation. My workshop only has an infra-red heater that is only on when Im in there. No dehumidifier either and I don't suffer rust issues. It is however an insulated building which keeps a stable temperature, or at least a slow-changing one.
                                          #387288
                                          Vic
                                            @vic
                                            Bisley shut their factory in Surrey about five or six years ago. I think they moved to wales?
                                            #387294
                                            clogs
                                              @clogs
                                              mechman48,
                                              hope those oil heaters are the oil in rad sort as burning parafin etc actually make moisture…….
                                              #387295
                                              fishy-steve
                                                @fishy-steve
                                                Posted by Vic on 23/12/2018 14:48:02:
                                                Hi Vic,
                                                Bisley are in Wales. Newport to be exact. I drive past their factory every day to work. They must be doing well as they have just extended the factory.
                                                Steve.
                                                #387305
                                                larry phelan 1
                                                  @larryphelan1
                                                  Or China ?
                                                  #387310
                                                  Andrew Tinsley
                                                    @andrewtinsley63637
                                                    Bisley draw systems are fine, but wall mounted they are not. So it is a waste of time recommending them for the OP's use.
                                                    I would also be interested in a wall mounting solution such as the OP has requested.
                                                    Andrew.
                                                    #387312
                                                    Brian Wood
                                                      @brianwood45127
                                                      Oh, come on Andrew, it doesn't take a lot of imagination to anchor the bare unit back to the wall with suitable screws through the frame, refit the drawers and then load them.
                                                      Bingo—wall hung!
                                                      Brian
