Sharpening
Sharpening
Home › Forums › Workshop Tools and Tooling › Sharpening
  • #316713
    Alan Gordon 4
      @alangordon4
      Hi Folks
      I have aquired a boring head with boring bars however thy have been well used and in need of sharpening, I have tried to sharpen on my bench grinder with poor results. Should I be using a different grinding wheel ?
      #18655
      Alan Gordon 4
        @alangordon4
        #316716
        richardandtracy
          @richardandtracy
          If they are brazed carbide tips, then you'll need a green wheel. If carbide inserts, they are disposable and should be changed. If they're HSS, then you either need to get better at the correct shape (and I am NOT one to talk – I resorted to cheap carbide insert tools from China, I was that good at grinding my own) or hone and maybe polish after grinding.
          Richard.
          #316717
          Brian Sweeting 2
            @briansweeting2
            What are the materials of the bars and the wheels, sorry can't see from here.
            #316729
            Alan Gordon 4
              @alangordon4
              Thanks Chaps
              Yes they are brazed carbide tips so it looks like i will invest in a green wheel or convert to inserts.
              #316735
              Andrew Tinsley
                @andrewtinsley63637
                A green wheel will not give a good enough finish for a really good surface, you will need to hone the cutting edges to get rid of the grinding marks.
                Andrew.
                #316740
                Douglas Johnston
                  @douglasjohnston98463
                  A diamond wheel is ideal for touching up these carbide tips.
                  Doug
