EMCO FB2 help
EMCO FB2 help
Home Forums Workshop Tools and Tooling EMCO FB2 help
  • #18135
    Paul McGee 1
      @paulmcgee1
      Ive damaged the vertical spindle assembly
      #245610
      Paul McGee 1
        @paulmcgee1
        Can any one help me with a potential supplier now that this part is discontinued by Emco.
        If not does anyone know the spec of this thread so that I can get it made.
        It looks like a Acme thread has about 16 tpi max dia .591" and might be LH
        #245611
          First port of call would be Pro Machine, they have got parts for my Emco lathe when I had it that had not been made for 20years.
          Hopefully a user on her can give you a part number and also more details of the screw, is it an imperial or metric machine?
          #245667
          Paul McGee 1
            @paulmcgee1
            Thanks Jason I have and they reiterated what I heard from EMCO's agent here in Australia that the FB2 isn't supported anymore so looks like I'm on my own – not quite thanks to all the help available from sites like these. So this morning I took the part to ACA Engineering, Geebung, Qld 4034 and Phil Fisher there said we'll do what we can to fix it up, $50. Probably $500 to make a new one. We decided its not an Acme thread but a square one.
            #245669
            Paul McGee 1
              @paulmcgee1
              Sorry haven't answered your full question.
              It's an Imperial machine and it's the vertical screw for lifting the milling head p/n E3B 000 130 and it's nut. All of which seems to be L/H thread. The steel used seems to have been quite soft so if I do have a new one made it will be of harder material.
              Maybe there's a market for making spare parts for the FB2 or at least buying up used ones and making the parts available. It's a nice little machine and it only cost me $600 so I can afford to spend a little bit on it.
              #245670
              Paul McGee 1
                @paulmcgee1
                I have the full instruction book and brochure so if anyone wants a copy I'm happy to share.
                #245675
                Jim C
                  @jimc
                  Hi Paul, I have a Rishton vertical mill which I am told was based on the FB2. I am looking for a manual for it to try and sort the backlash that exists in the Y axis. Therefore I would be interested in a copy of yours as the two machines do look rather similar when you look at them on the Lathes website. Thanks, Jim.
                  #245678
                  Paul McGee 1
                    @paulmcgee1
                    Give me your email Jim and I will scan and send the pages that should help you.
                    #245681
                      Sounds like a similar leadscrew to the one I had on my Emcomat 8.6 which was 16tpi square thread and probably 15mm OD from memory.
                      Looking at an exploaded diagram online the easiest option may be to modify a standard Acme or trapizoidat leadscrew which are easily avalable and modify a standard nut to replace the Emco one.
                      There were several copies of the EB2 but they may not have used an exact match to the thread
                      Edited By JasonB on 07/07/2016 08:18:48
                      #245683
                      Douglas Johnston
                        @douglasjohnston98463
                        I had that same make of machine some time back and would follow Jason's advice and use off the shelf acme threaded rod and an acme nut. If my memory serves me correctly it would be quite easy to do this and would be much cheaper. You probably wouldn't get 16 TPI threaded rod easily off the shelf but you could use 10 TPI which would make more sense on an imperial machine.
                        Doug
                        #245690
                          Here's a source in the USA that seem to be able to supply almost any conceivable leadscrew & nut… except square., of course!
                          Edit –  for 16 tpi., 3/8" L/H about 50 USD + delivery for two feet of leadscrew and a bronze nut.
                          Edited By Neil Wyatt on 07/07/2016 09:28:41
                          #245691
                            Some interesting stuff in their FAQ section.
                            http://www.roton.com/faq.aspx
                            Particularly they state there's no benefit in using special steels if you have a bronze or plastic nut.
                            Edited By Neil Wyatt on 07/07/2016 09:32:50
                            #245692
                            John Stevenson 1
                              @johnstevenson1
                              Doesn't the Imperial mini mill use a 16 tpi leadscrew ? Not sure if it LH though ?
                              #245695
                                Would not really matter if it were left or right once you got used to it.
                                I'd try and get a diameter close to the existing so the end can be turned down to take the handwheel, fit the top bearing, etc.
                                I can't see to get the Emco Yahoo group now, although mainly aimed at lathes it did have some bits about the mills.
                                #245696
                                steamdave
                                  @steamdave
                                  In order to reduce inevitable wear on the Z axis leadscrew, I always give the head a helping hand by turning the handle in one hand and using my other hand to relieve most of the weight.
                                  I know that there are counterbalance systems for some of the far eastern mills, but they are not so easy to fit on an FB2.
                                  The Emerald Isle
                                  #245702
                                  Paul McGee 1
                                    @paulmcgee1
                                    Thanks Neil I have emailed Roton – good find.
                                    #245703
                                    Paul McGee 1
                                      @paulmcgee1
                                      Hm lost a reply
                                      I had said guess what in desperation I emailed EMCO and asked for the original drawings of the spindle and they sent them straight back !
                                      It is a ACME thread , the drawing spec says 15mm dia16 tpi links geraullt 6g
                                      Then it has a note "Die Steigung darf gemessen innerhalb einer beliebigen Anzahl von Gangen , jedoch max auf 12" Lange nicht mehr als 0.0012"vom solmass abweichen" German anyone ?
                                      #245704
                                      Paul McGee 1
                                        @paulmcgee1
                                        Good point Steam Dave !
                                        I forgot to say a big thanks to you all for pitching in.
                                        Paul
                                        #245787
                                        Bikepete
                                          @bikepete
                                          The pitch may be measured over any number of threads, but it may not deviate from nominal by more than 0.0012" over a 12" length.
                                          #245808
                                          duncan webster 1
                                            @duncanwebster1
                                            I think that the mix of units 15mm OD * 16 tpi means you're unlikely to find off the peg leadscrew to suit. I think Warco used to sell a clone of the FB2, it might be worth asking them if they have the spare parts and whether they would sell them on the basis that if they didn't fit you could send them back. If they were near you might modify.
                                            Otherwise ABSSAC sell 5/8" 10 tpi screws and nuts, you'd need a new scale on your handwheel, or fit a DRO and ignore the scale
                                            #265923
                                            Jon Gould 1
                                              @jongould1
                                              Paul I would also like a copy of the manual if at all possible.
                                              #265960
                                              Robbo
                                                @robbo
                                                Jon,
                                                Message me if Paul doesn't see this.
                                                #266273
                                                Robbo
                                                  @robbo
                                                  Jon,
                                                  See your messages
