Hello folks, like lots of other chaps I occasionally need to run a die along rod held in the lathe chuck. At the moment I use an ordinary hand-held die-holder, and put a flat ended centre in the tailstock to bear against the back of the die to get the thread started nice and square. I then have to juggle tailstock feed, die-holder handle, and chuck in order to progress, but only until the rod emerges from the back of the die whereupon the tailstock has to be withdrawn.
Now I'm thinking of acquiring a tailstock die-holder but am swithering between the sort with a guide pin which prevents rotation of the die, and allows just straight sliding feed, or the type where torque is applied via a side arm, and the die can be rotated back and forth to some extent.
I'd like to know if you have a strong preference for one type over the other, and how you deal with the need to back off the die periodically to break up the chips when using the pin-guided type. Is it all down to chuck rotation in that case? Sorry if these sound like daft questions, but humour me, please.
