LBSC Mollyette Locomotive Build
Home Forums Locomotives LBSC Mollyette Locomotive Build
  • #200703
    fishin23
      @fishin23
      Hello everyone,
      I am new to the forum and have started building my O gauge Mollyette loco a few months ago, thought I join up and have a chat with other model engineering builders and learn something along the way as this is my first loco build.
      I have cnc machined wheels first and started building up from there. Hope you like what I have done.
      Cheers Mark
      #1437
      fishin23
        @fishin23
        #200704
        fishin23
          @fishin23
          #200705
          fishin23
            @fishin23
            #200720
              Welcome Fishin, those wheels look the business!
              fishin23
                @fishin23
                Thanks Neil, I found some cast iron at work the right size and just designed them in solid works to a design that looked right and went from there, turned them in the lathe first and then over to the mill, I,m very happy with the look of them. Mark
                #200994
                Another JohnS
                  @anotherjohns
                  Hi Mark – very nice work.
                  Questions: end mill size? (more than one, ball end mill, etc?)
                  What's the tread diameter of the wheels?
                  Always nice to see CNC work to help advance our model building.
                  John.
                  #201068
                  fishin23
                    @fishin23
                    Hi John,
                    The wheels are 28.8mm in diameter, i used a carbide 2.5mm slot drill for roughing and a carbide 1.5mm ballnose at 10,000RPM for finishing, i am lucky enough to be able to sneak a few jobs onto the machine at work.
                    I turned the blanks first , and due to these small cutters only having small flute lengths i machined the back side of the spokes to half depth, flipped the wheels over and machined the other side,i also machined a simple jig with small islands which locate into spokes and has some small clamps that clamp on the wheel rim.
                    Mark
                    #201132
                    Another JohnS
                      @anotherjohns
                      Hi Mark – thanks for the answers.
                      I have drawn up the Q1 wheels (3-1/2" gauge) but have not machined them yet; right now I'm finishing a 3-1/2" gauge Shay and have been looking at the 3-1/2" gauge Heisler geared locomotive, which has wheels about 50mm diameter.
                      Although we have one very large shop @work, I do machining at home; my smaller mill will go to 7,000 rpm so it's close. (I do not want to mix work and hobby, for many reasons)
                      Keep up the progress – JohnS.
                      #201201
                      fishin23
                        @fishin23
                        #201202
                        fishin23
                          @fishin23
                          Hi John, i thought i would start off small to test myself and then maybe start something bigger like you have.
                          I have attached a pic of the boiler i started, all nice and neat until i silver soldered it.
                          Mark
                          #204422
                          Mitchell Jones
                            @mitchelljones
                            Mark
                            I do not know if you are using the plans from myhobbystore.com or not, but just in case, I have included a link to a previous forum thread on Mollyette: **LINK**
                            "Dave" was having issues with some of the measurements.
                            Great thread, keep it going!
                            Mitch
                            #252065
                            fishin23
                              @fishin23
                              img_0330.jpgimg_0327.jpgHi everyone,
                              I have been chipping at my little loco. Boiler is almost completed. The mechanical's have been through an air test and the little loco came alive without any hiccups. I have attached some pics.img_0178.jpg
                              Regards, Mark
