Power hacksaw blade choice
Home › Forums › Manual machine tools › Power hacksaw blade choice
  • #460687
    Adam
      @adam
      Hi everyone, I have almost finished restoring my grandfathers power hacksaw and I've just been testing it. I think the blade is past it (no idea of its age) and wondering what would be the best blade to replace it with. It currently has a 300 x 25 x 26TPI blade.
      I will mostly be cutting aluminium and stainless steel bar up to 3 inches diameter.
      I'll do a restoration write up one complete.
      Adam
      #13819
      Adam
        @adam
        #460703
        Steviegtr
          @steviegtr
          Using the 3 teeth rule I guess you need to estimate the smallest size of cut. Obviously too fine & it will clog Aluminium too easy. Only going on the one we had in a workshop were I once worked.
          Steve.
          #460704
          Clive Brown 1
            @clivebrown1
            26 tpi is way too fine IMO. I use 10 tpi in my Rapidor as a general purpose blade which seems to work well.
