Pittler lathes information needed
Home › Forums › Manual machine tools › Pittler lathes information needed
  • #417657
    vic newey
      @vicnewey60017
      Has anyone got a Pittler lathe who can take a measurement for me? I need the diameter of the circular carriage block that the cross-slide bracket swivels on (and some of the attachments are fitted). Mine is 78mm, measured across the clamp of it's traveling steady.
      I want to see if there is a similarity or a wide variation as I'm seeking other attachments which may or may not fit.
      I'm particularly looking for the original supplied cross-slide, the type on a vertical stem that can be swiveled in all directions. Mine has the extra long compound slide mentioned in old ME magazines by George Gentry but it does not permit the multiple angles of the original
      Edited By vic newey on 06/07/2019 21:09:39
      Edited By vic newey on 06/07/2019 21:10:00
      #13582
      vic newey
        @vicnewey60017
        #417735
        Phil Whitley
          @philwhitley94135
          #417744
          vic newey
            @vicnewey60017
            Posted by Phil Whitley on 07/07/2019 13:19:48:
            http://www.lathes.co.uk/pittler/index.html is a good start.
            Not really, it does not give measurements other than distance between centres
            #417763
            Phil Whitley
              @philwhitley94135
              email [email protected], if he doesn't have one in his collection, he will know someone who has!
              #417778
              vic newey
                @vicnewey60017
                Posted by Phil Whitley on 07/07/2019 16:42:00:
                I have emailed Tony but I never get a reply,
                #437941
                vic newey
                  @vicnewey60017
                  Gerard O'Toole.
                  I replied to your email re Pittler lathe
                  #438105
                  Gerard O’Toole
                    @gerardotoole60348
                    Hi Vic,
                    Just replied to your email
