Silvers soldering
Silvers soldering
Home › Forums › Beginners questions › Silvers soldering
  • #453574
    Peter Simpson 1
      @petersimpson1
      When silver soldering what is the best method of ensuring that other parts in close proximity to the "joint" does not get soldered. I have made a jig to make some lifting arms. I do not want the arms getting soldered to the jig ?
      #10086
      Peter Simpson 1
        @petersimpson1
        #453578
        Jim Nic
          @jimnic
          I use a coat of Snopake typing correction fluid where the solder is not to flow. (Note that this fluid will not correct machining errors!)
          Jim
          #453580
          Former Member
            @formermember19781
            #453587
            john fletcher 1
              @johnfletcher1
              Lamp black from a candle will also work. When plumbers used lead pipe they used a substance in a Yellow tin called "Plumbers Black" to keep things tidy. They used an old paint brush, dipped it some water, gave it a shake, scrubbed around on top of the black cake and painted it around the pipe, forming a neat band, which prevented solder from going where it wasn't needed. Under ground cable jointers did the same. I have been searching for a supplier for "Plumber Black" for quite some time. It would seem plumber now use plastic pipe where ever possible. John
              #453592
              Former Member
                @formermember19781
                #453594
                HOWARDT
                  @howardt
                  Off topic. Some years ago I was told by one of the copper fitting manufacturers, one reason for solderless fittings was having to have a fire Marshall standing by the plumber in refurb buildings during naked flame soldering.
                  #453596
                  Speedy Builder5
                    @speedybuilder5
                    Bill, are gas pipes plastic and compression fittings these days as well ?
                    #453597
                    Steve Skelton 1
                      @steveskelton1
                      I find a little jewellers rouge made into a paste with water and painted onto the surface works best for keeping silver solder from spreading where it isn't wanted.
                      Steve
                      #453598
                        If you use correction fluid as I do it should be the solvent based one.
                        #453613
                        Nick Clarke 3
                          @nickclarke3
                          Wondered what 'Plumber's black' could be so did an internet search.
                          First few results were local plumbers followed by a whole stream of XXXXX adult websites.
                          The world we live in today!
                          #453616
                          Former Member
                            @formermember19781
                            #453619
                            Peter Simpson 1
                              @petersimpson1
                              Jason which one should I look for. Not sure which ones are solvent based.
                              #453628
                                The one they call Tipp-ex rapid like this
                                #453630
                                Dave Halford
                                  @davehalford22513
                                  Posted by john fletcher 1 on 22/02/2020 15:27:50:
                                  Phone cables were poly and already being jointed with epoxy back in the late 60s, that boat left a very long time ago along with all the lead cables
                                  #453657
                                  Paul Lousick
                                    @paullousick59116
                                    Jason,
                                    What do you use to remove the Tipp-ex after soldering? I find it difficult to clean up after it has burnt on.
                                    Paul
                                    #453665
                                      You can paint on Milk of Magnesia and let it dry. The solder/braze will not stick to the dried magnesium powder.
                                      #453671
                                      Jim Nic
                                        @jimnic
                                        Paul
                                        I don't know how Jason removes Tippex, but I find that what I use easily comes off along with any burnt/dried flux residue in the pickle bath and after with a scrub with a toothbrush. (Don't let on to the better half whose toothbrush you use for this.)
                                        Jim
                                        #453681
                                          My pickle removes it along with HT5 flux in about 1/2hr, I use Feb brickclean that contains hydrochloric acid
                                          #454065
                                          Dennis R
                                            @dennisr
                                            Tipp-ex rapid double pack is on offer at £2.99 in W H Smiths today, seems very good value.
                                            Dennis
                                            #454516
                                            Peter Simpson 1
                                              @petersimpson1
                                              Bill this a photo of an embryo lifting arm mounted on the jig prior to silver soldering jig.jpg
                                              #454518
                                              Peter Simpson 1
                                                @petersimpson1
