Zinc-Rich Primer
Zinc-Rich Primer
Home › Forums › The Tea Room › Zinc-Rich Primer
  • #36942
    Swarf, Mostly!
      @swarfmostly
      #609448
      Swarf, Mostly!
        @swarfmostly
        Good afternoon, all,
        I have a rather tired half-full tin of Galvefroid zinc rich primer and a metal shed with a rusty roof.
        I'm posting here in the hope that our numbers include a paint chemist or two who can advise me about this primer.
        It has gone rather hard in the tin over the years since I last used it. Will it have cured irretrievably or might I be able to revive it by adding the right thinners and some elbow grease?
        I'd much rather use it than scrap it. I'm fairly confident that white spirit (aka turps substitute) isn't the right thinners. I do have some Hammerite thinners, might that do?
        I'm asking here in advance rather than proceeding on a 'suck it and see' basis – I fear that trying the wrong stuff might be irreversible!
        Best regards,
        Swarf, Mostly!
        #609451
        peak4
          @peak4
          I have some like that myself; The Datasheet Here, suggests Naptha
          https://www.promain.co.uk/fosroc-galvafroid-thinner.html
          Bill
          #609452
          John Rudd
            @johnrudd16576
            We used ‘Genklene’ when I was at ICI, 1.1.1. Trichloroethane commonly known as, if you can still get it….
            #609465
            Jim Young 2
              @jimyoung2
              Experiment with a spoonful in a baked bean tin perhaps?
              #609473
              Oldiron
                @oldiron
                I thinned some Galvafroid last year for an outside job with Zylene from Crosbie Coatings. Took a lot of mixing by hand but it applied ok and has stood up to the weather fine and I have still not overcoated it.
                regards
                #609479
                KWIL
                  @kwil
                  Zylene is almost certain to be the aromatic hydrocarbon used. Look up the Safety Data Sheet for Galvafroid, 30% aromatic in the correct R group numbering. Just difficult to stir the semi hardened paint!!
