What gauge boiler tubes and expanders?
Home Forums Beginners questions What gauge boiler tubes and expanders?
  • #6162
    nigel jones 5
      @nigeljones5
      #91406
      nigel jones 5
        @nigeljones5
        Ibe given up on the large tube aproach – no one seems to think its a good idea so I will opt for 7/16 copper tubes (I know this also carries its own cons in a steel boiler but lets not go there for now). Wil I get a better seal with 16g or 20g (I assume wall/rigidity plays a part in this? No fancy tube rollers im afraid, it will either be a hammer it home tapered mandrel or a tighten and squash rubber gromit jobby, again, any advice welcome…
        #91413
        MICHAEL WILLIAMS
          @michaelwilliams41215
          Hi again ,
          A lot depends on whether the tubes just act as flues or whether there is substantial dependency on them as load carrying stays as well .
          Full size tubes were fitted in lots of different ways early on but the favourite was 'clunking' (to use R Stephensons delightful term ) . Basically tubes were made with a bit sticking out each end and after expanding into tube hole the ends were rivetted over – giving a very sound joint .
          There are two designs of simple expanded fitting :
          (a) Expanded into the hole but no more – will seal against pressure but not reliably hold against end loading .
          (b) Expanded so that two 'larger than the hole' circular bulges form – one inside and one outside . This is a very strong fitting and will seal against pressure and take end loads .
          Other methods use rammed in ferrules and (just rarely ) screwed on ring nuts .
          Notes :
          To do expanded tube joints properly they have to be dry fitted . No sealant and no solder .
          There is no certainty that either thickness of tube that you mention is better than the other for making expanded joints . My best guess would be 18 swg but you would have to do some test assemblies to be sure .
          The tubeplate holes have to be properly designed to avoid the tube expanding process from simply shearing the tubes off .
          Thats it for now .
          Michael Williams .
          #94093
          nigel jones 5
            @nigeljones5
            How does one design the right hole?
            #94094
              Most of the tube expander suppliers give the spec for the hole for a given dia and thickness of tube.
              This thread on HMEM has some chat about expanders that may be handy
              Edited By JasonB on 10/07/2012 19:05:48
