What Did You Do Today (2017)
Home › Forums › The Tea Room › What Did You Do Today (2017)
Viewing 25 posts - 1,476 through 1,500 (of 2,518 total)
  • #307837
    Martin Kyte
      @martinkyte99762
      Set up a few things for our Lab Art Show. Photo posted in my album.
      Pair of Oak side tables, Vertical Steam Engine, Stuart Turner Engineering Lathe, Spherical Turning Tool.Hand Turning rest, Versatile Dividing Head and Tailstock + Raising Blocks for Milling Machine and a couple of stoneware pots.
      Too many interests, too little time.
      regards Martin
      #307843
      Jim Nic
        @jimnic
        An impressive range of skills Martin!
        Jim
        #307847
        Martin Kyte
          @martinkyte99762
          Thankyou.
          #307849
          Ady1
            @ady1
            I've spent the last couple of days cleaning up an old gate for someone I know
            It was made of cast iron from the 1920s and had some horrendous scale and rust and about 20 coats of paint
            I took it on as a "restoration" type experiment since it was an original feature from the house build, but it really looked like it should be condemned and replaced
            Anyhoo, after a bit of work it got repainted and looked passable (would take about a week, with car body filler, to make it look 'good'  ) and the oscillating saw was fantastic, making all the nightmare bits of thick paint, scale and rust relatively easy to remove
            So if you come across an "impossible to save job" consider an oscillating saw for all that chipping and scraping work, they really are quite amazing
            Edited By Ady1 on 19/07/2017 11:05:49
            #307857
            Muzzer
              @muzzer
              I take it you didn't actually use a saw blade for the job. Did you have some sort of wire brush attachment?
              #307862
              Ady1
                @ady1
                It has a standard scraper attachment. Made light work of a crappy job, cutting through the thick rust and paint
                Works sideyways too, like a chipping hammer on tough scale
                When I first bought it I wondered if it would ever be useful, silly me
                (Edit: I worked all afternoon til 5pm in the blazing hot sun too, not so easy at my age)
                link
                Edited By Ady1 on 19/07/2017 14:25:20
                #307863
                Muzzer
                  @muzzer
                  Haha I've got one of these Bosch power chisels. Mainly intended for wood carving but comes with a carbide edged scraper which is great for cleaning flat surfaces. One of my work colleagues was good enough to assess the effectiveness of all of the chisels (not just the scraper) at removing ceramic floor tiles from concrete flooring. I won't be using it for wood carving again but perhaps it might still be up to a rusty old gate.
                  Murray
                  #307864
                    Posted by Martin Kyte on 18/07/2017 09:40:29:
                    Posted by Neil Wyatt on 16/07/2017 15:43:04:
                    Final results of my camera butchery. Other people's experience suggests I may get as much as 30 degrees C of cooling.
                    How much shake do you get from the fan?
                    regards Martin
                    None I can detect. I avoided ball bearing ones and luckily found a 'hydrostatic' one that fitted the heatsink and its effectively silent and vibration free
                    > I expect the hands frozen to the camera at -30 degrees cancel it out
                    Funnily enough the inside of the camera only drops by 6-8 degrees, but the sensor is probably dropping 25-30 degrees.
                    On my trial I had big condensation problems – expected as I was only putting about 0.2 watts into the front glass heater, I've supped this to 0.25 watts which most people find about right, but I could go up to 0.5 watts.
                    #307868
                    richardandtracy
                      @richardandtracy
                      Posted by Muzzer on 19/07/2017 14:42:33:
                      Murray
                      A previous owner of our house had had the great idea of using wall tiles on the floor of their brand new kitchen extension in the 1980's. They used a good floor tile adhesive. The glaze rapidly wore through, so they put quarry tiles on top, again with a good adhesive. We wanted something warmer to stand on that didn't smash plates when you dropped them, so I got the removal job.
                      I used a hammer & bolster & got the quarry tiles up easily. The wall tiles were another matter. It took 30 minutes with a hammer & chisel for a 4"x4" tile, slowly pulverizing the tile. I ended up buying an Argos special SDS hammer drill with roto-stop & a set of chisels. Took a further 4 hours to reduce the remainder of the tiles to powder. Very satisfying job, but I'd love to strangle the little so&so who thought it'd be a good idea to use wall tiles on the floor.
                      Richard.
                      #307870
                      KWIL
                        @kwil
                        You were lucky the floor tiles were not porcelain, they are about as hard as you can get.
                        #307871
                        Muzzer
                          @muzzer
                          Don't remind me. I have 2 layers of floor tiles to lift in the kitchen, to be followed by laying new floor tiles in both this and the new (adjoining) dining room, total area must be a bit over 25 m2. Obviously I will be buying the biggest possible tiles I can find. For the first stage I have an SDS drill that will be used as a power chisel and a Big Mutt in case that doesn't work….
                          #307892
                          Clive Hartland
                            @clivehartland94829
                            A bit off to one side here, I want to lift some carpet tiles that are stuck to Vinyl. I seem to remember they used a carpet adhesive in a spray can. What have members used to get the adhesive off the vinyl tiles?
                            #307894
                            Clive Hartland
                              @clivehartland94829
                              Have started to take honey off the bees, took two boxes on Tuesday uncapped and spun out and bottled all in one day. This year for a change they were able to work the Blackberry and the honey tastes very nice and has a beautiful fragrance.about another 5 boxes to go yet.
                              #307896
                                Helpful sticker under the bonnet of the Fiat…
                                Brakes: we recommend you use Dot 4 fluid
                                Same for washer bottle and radiator, they give a suitable spec.
                                But the prize is right at the top of the list:
                                "Engine Oil: We recommend you use oil"
                                I guess Olive Oil would be best for a Fiat?
                                #307911
                                martin perman 1
                                  @martinperman1
                                  Gentlemen,
                                  For the last ten days I have blitzed my garage and returned it to a workshop, I've still got a window assembly to repair and a bench to clear but after at least five trips to the local tip to dispose of anything and everything I'm nearly there. Today I have had to teach myself a new discipline, having recently retired I no longer have the use of a transit sized van so as I'm off to Ducklington Vintage rally this weekend and I've had to get all of my camping equipment etc into the back of my recently purchased Forester including a portable fridge, stove etc. The engine is strapped into my trailer.
                                  Martin P
                                  #307912
                                  roy entwistle
                                    @royentwistle24699
                                    Martin P I hope you don't mean the engine of the Forester
                                    Roy smiley
                                    #307915
                                    NJH
                                      @njh
                                      " I have 2 layers of floor tiles to lift in the kitchen"
                                      Ah that brings back memories!
                                      We have an "upside – down" house with the living rooms and kitchen upstairs and bedrooms down stairs. The kitchen was floored with ceramic tiles and we had two Staffies who slept in there at night. We soon found that an alarm clock was not required – as soon as the dogs woke up it was like the Household Cavalry on manoeuvres going on above our heads! This situation was resolved by bringing the dogs downstairs…. We have a high bed ( 1metre +) off the floor so we put their beds under our bed and all went well…….. except that in the night they would jump up onto the bed and lie on top of the duvet pinioning us to the bed!!
                                      That situation too has now resolved itself – our latest dog ( see my avatar ) is related to the original pair and she comes downstairs at night…. but has her bed in the utility room which suits her – and us – very well!
                                      ​I chiseled those ceramic tiles off the kitchen floor – every one broke and in some cases I was getting off small pieces about 12mm x 12 mm grrrrrrrrr! I got the local flooring guys to come. They laid hardboard all over the floor and nailed it down firmly before laying a heavy duty vinyl flooring sheet over it. Fantastic – problem solved!
                                      Norman
                                      Edited By NJH on 19/07/2017 20:19:52
                                      #307916
                                      martin perman 1
                                        @martinperman1
                                        No smiley the Lister Hamworthy compressor set I'm displaying.
                                        Martin P
                                        #307945
                                        Pero
                                          @pero
                                          I have used citrus oil to remove these gummy types of glue in the past. It works by breaking down the glue and its adhesion.
                                          You need to cover the glue with a thin coating of the oil and leave it to work for a while (don't rush it) and then it should wipe off – paper towel is a good option here. A couple of goes may be required for stubborn patches. It should not damage the vinyl but will leave it slippery until thoroughly washed off.
                                          It is available under various names from the cleaning section of hardware stores or supermarkets.
                                          Pero
                                          #307946
                                          Bill Pudney
                                            @billpudney37759
                                            Made 6 or 7 threaded inserts on my new (to me!) Schaublin 70 Turret lathe. Yes I know I could have bought them, but the only ones I've seen are brass, I wanted Al. Alloy. Anyway, it took about an hour to set the turret up, with the appropriate strokes, and about 2 minutes each to make the inserts. The longest operation was drilling the hole for an M3 thread. Parted the last one off at about 2,500rpm, which was a bit of a revelation!!
                                            cheers
                                            Bill
                                            #307959
                                            duncan webster 1
                                              @duncanwebster1
                                              Posted by Neil Wyatt on 19/07/2017 18:42:56:
                                              I wouldn't put dot 4 fluid in the screenwash if I were you!
                                              I'll go and walk the dog
                                              #307986
                                              Windy
                                                @windy30762
                                                After my morning moan put a heavy tool etc. cabinet on a castor frame I made yesterday as strength is not a strong point at the moment so anything to ease moving things.
                                                A bit damp this morning but the bees, hover flies plus other insects are still busy on the Globe thistles and other flowering plants.
                                                A bit of my light humour a picture of a speed nuts view at the kitchen sink showing my fondness for recycling and the must have beauty cleaner the Art Nouveau flower vases with sweet peas I find most attractive.
                                                That add for Persil with Robbie Coltrain so much reminds me of myself all those sprinting years ago in Mums kitchen.
                                                A picture of that lasses fast machine at rest after last Tuesdays 249mph despite a head wind at my Spiritual home.
                                                Image may contain: plant
                                                Image may contain: 1 person
                                                Edited By Windy on 20/07/2017 13:02:58
                                                Edited By Neil Wyatt on 20/07/2017 17:55:01
                                                Edited By Neil Wyatt on 20/07/2017 17:55:33
                                                #308001
                                                Robbo
                                                  @robbo
                                                  Funnily enough I was thinking only yesterday that we hadn't heard from Windy lately, and hoped he was OK.
                                                  And here he is – hope everything is proceeding well Windy.
                                                  And my sweet peas are looking and smelling great just now. smiley
                                                  #308004
                                                  mechman48
                                                    @mechman48
                                                    Finally got rid of all the NVQ training notes that I'd accumulated over 25 years ago when I was Mech Eng. NVQ L2/3 instructor at a training centre in my area. Blinking heck the amount of photocopied / handwritten text, handouts, OHP's, ref books, assessor forms, I/V documents that was stored in my loft was no body's business, why I kept them this long ??… todays teaching is all electronic portfolios & Google etc. ref. Ah well more space to put something else in.
                                                    George.
                                                    #308006
                                                      Posted by Windy on 20/07/2017 13:01:27:
                                                      Nice bike and a fun photo! Looking closely I think I can see 4 people in the picture. Is that right?
                                                      Lovely garden behind the taps too. When it comes to beauty treatments, I find putty hides the damage better than Orange Swarfega.
