What did you do today (2015)
Home › Forums › The Tea Room › What did you do today (2015)
Viewing 25 posts - 1,626 through 1,650 (of 3,154 total)
  • #194758
    alan smith 6
      @alansmith6
      Hi All,
      I`ve just bought a Deckel FP1 milling machine from 1964, this was an impulse buy and it came with a large cabinet of accessories.
      The sump had not been cleaned out for many years so I started to clean it out using the siphoning device but the fine swarf in the oil clogged up the non return valve so that I had to resort to spooning the oil out with a sauce ladle.
      The oil has the consistency of black slime with jelly and is very unpleasant. The sump goes all the way under the base and cannot be cleaned out properly from the two access holes.
      Has anyone any ideas of how I can clean out the remnants in the sump.
      Alan
      #194759
      Swarf, Mostly!
        @swarfmostly
        Hi there, Alan,
        Could you insert some packing under the rear of the machine and then insert the hose from a wallpaper steamer through the access holes?
        Maybe do a test first to see if steam heat renders the 'gunge' fluid enough to drain to the front.
        Best regards,
        Swarf, Mostly!
        #194760
          Posted by frank brown on 24/06/2015 18:55:51:
          I;ve cracked 1.2mm (I think). . .24 on spindle meshing with 60 on shaft with a 38 which drives a 36 into the 2:1 leadscrew gear box. Ten turns on the chuck is 12mm -+ .00 on a reasonabley priced (cheap) digital vernier.
          I have looked at calculating other ratios, I think 1mm is 20,60,38,36. Like 1.2 but lead screw is rotating 20% slower, hence change from 24 to 20 as the spindle gear. In the same vein, 1.5mm should be 30+60+38+36.
          .8mm and ,7 are inscrutable at the moment, 1.25 needs a 25 tooth gear which I have not got.
          Frank
          Should that not be a 36 driving the 38?
          24/60 = 0.4
          36/38 = 0.947
          0.2 x 0.947 x 0.5 = 0.1894 of a turn x 6.35 = 1.203
          #194761
          Nigel McBurney 1
            @nigelmcburney1
            Went for pub lunch today (southern England)with my wife ,builders were working on old outbuilding,one on ridge refitting capping tiles ,one on scaffold with big disc cutter, cutting tile with loads of dust,third man painting new gable end timber with black paint (no priming),result dust all over paint and over customers and cars!!.I just could not believe what happened next,painter came down ladder ,paint pot was on ground, builder puts brush in paint and then goes back up ladder,paints a bit then comes down to refill his brush,does this several times,Where do these clowns come from?
            #194763
              3 points of contact so could not hold brush and paint pot, thats HSE for you
              #194772
              Ian P
                @ianp
                Posted by Nigel McBurney 1 on 24/06/2015 19:47:45:
                Not sure why you thought that scenario was worth posting about, seems a very normal set of builders to me!
                A few years ago I watched a highly skilled plumber putting holes in chipboard flooring (in what would eventually be the cylinder cupboard) with nothing more than a claw hammer. With the right weight hammer, swung 'properly' and aimed accurately at the hole position, a nice circular aperture is made to take the 15mm tubing.
                I tried it and wasted a lot of chipboard before I made one hole, so I know it needs the skill of a plumber.
                Ian P
                PS, I forgot to say the neat round hole was only on the top face, the underside flaked off to about five times the diameter
                #194776
                Nicholas Farr
                  @nicholasfarr14254
                  Posted by JasonB on 24/06/2015 19:53:20:
                  Hi, guide lines for working at heights can be found at **LINK** this is of course aimed at anyone being employed, or employing others. When working at home for yourself, you don't have to follow these guide lines, but it would be very prudent to do so, because ignoring these guidelines can lead to an accident that may cause a serious disability for the rest of your life or end it completely.
                  Regards Nick.
                  #194777
                  Clive Hartland
                    @clivehartland94829
                    Bees again, I related the loss of Queen bees, so today I visited a very nice lady near Folkstone who breeds Queen bees. she has a set up that allows her to create Queens in mini hives and they can fly out and mate and she can then offer mated Queens for sale.
                    My trip down there was complicated by the Operation stack because of the Calais strike. Because of this I went via the M2 past Canterbury and followed signs to Folkstone, and saw a road sign to the place I wanted to go to so through all the country lanes so narrow the grass was brushing the side of the car. Met up with the lady and we exchanged cash for the Queen and I made my journey home, but this time back up the M20 as the Westbound road was clear of lorries. They said there were 13 miles of lorries but I reckon on nearly 20 miles of parked lorries 99% foreign.
                    Getting home I diverted to the Apiary and soon had the new Queen in her cage set up between the combs where the bees will slowly eat away the candy plug and release her, meanwhile accepting and taking Queen pheromone from her.
                    In a few days I will look in and see how she is.
                    #194816
                    john carruthers
                      @johncarruthers46255
                      Yesterday we visited my wife's 'old uncle Bern', a retired fitter of the old school. Sadly he is setting his afairs in order and generously gave me some of his old tools. A very personal bit of kit were his Snap-On 4" files, c1970 made by Nicholson, he used them every day of his working life but like him, they are still keen.
                      Then when I got home a new Grobet 8" #2 file had arrived. I shall definately be buying more of those thumbs up
                      Also today; "something crated this way comes" wink 2
                      #194828
                      Jon Gibbs
                        @jongibbs59756
                        Posted by Nicholas Farr on 24/06/2015 21:39:40:
                        Not sure whether you've seen this but it's good viewing.
                        I agree with the sentiment of the post but Fred D wouldn't have got very far following those HSE guidelines
                        Jon
                        #194832
                        Clive India
                          @cliveindia
                          Posted by Clive Hartland on 24/06/2015 21:40:05:
                          Bees again,…..
                          Getting home I diverted to the Apiary and soon had the new Queen in her cage set up between the combs where the bees will slowly eat away the candy plug and release her, meanwhile accepting and taking Queen pheromone from her. In a few days I will look in and see how she is. Clive
                          May you have success Clive – there is more to this than I thought. Keep us informed.
                          #194843
                            'ooray for Fred. My grampy looked just like him – but a bit greater in the girth
                            Ian S C
                              @iansc
                              It seems that if I want to clean the spouting around my house I'm OK, but if I want to do someone elses I'd need a scaffolding put up, same goes if I get someone else to do mine. Some of this is going to change, the NZ Govt has a committee, to get rid of some of the silly regulations.
                              Ian S C
                              #194877
                              john carruthers
                                At last, the lathe fairy came in the night.
                                An SC3 from Arceuro.
                                Spent the morning degreasing and fettling.
                                Edited By john carruthers on 25/06/2015 14:29:50
                                #194879
                                mark costello 1
                                  @markcostello1
                                  How Fred D ever lived to die a natural death is beyond Me. Shear genius coupled with nerves of steel. Across the pond He is unknown. This BBS is the only way I learned of Him. What an original! Would have loved to watch in person.
                                  #194880
                                  Capstan Speaking
                                    @capstanspeaking95294
                                    Fred was a totally self-taught engineer. Limitless enthusiasm.
                                    If you like Fred you should look on Youtube for Derek "Blaster" Bates.
                                    #194883
                                    Dennis D
                                      @dennisd
                                      Thanks for the Youtube heads up. Used to have all his records at one time, nice to put a face to the voice.
                                      #194887
                                      richardandtracy
                                        @richardandtracy
                                        Posted by Ian S C on 25/06/2015 14:19:42:
                                        …. Some of this is going to change, the NZ Govt has a committee, to get rid of some of the silly regulations.
                                        Ian S C
                                        The same thing is supposed to happen here in the UK. I don't believe one word of it. If you get rid of a regulation, a department of government will have to admit they were wrong in over-regulating. That sort of admission is completely impossible to expect of a Government employee, let alone a department.
                                        Richard
                                        Edited By richardandtracy on 25/06/2015 16:06:35
                                        #194897
                                          Roderick Jenkins
                                            @roderickjenkins93242
                                            Clive,
                                            Help! A swarm has settled down on the branch of an oak tree overhanging our garden, about 20 feet up.
                                            What happens next?
                                            Rod
                                            #194901
                                              @mike89748
                                              Bought myself a pair of heavy-duty tin snips – £3.99 from Lidl. Seem identical to a pair I bought for £15 25 years ago, and which are finally worn out. And I only went into Lidl for a couple of bottles of beer…
                                              #194902
                                              Bowber
                                                @bowber
                                                Just watched some of them FD vidoes, I'm not good with heights so now I feel slightly ill. face 21
                                                I used to have to work on the top of cement and Ash silos and they were bad enough with hand railings, caged ladders and stages, to climb up a single run of ladders and have nothing in the way of safety equipment just makes me come out in a sweat.
                                                He's right about the feeling of a tall object swaying in the wind though, it is kind of relaxing.
                                                Steve
                                                #194908
                                                  What happens next?
                                                  Rod
                                                  B Movie
                                                  #194923
                                                  Clive Hartland
                                                    @clivehartland94829
                                                    A man in a bee suit comes along with a box and shakes the branch and the bees fall down into it and he places the box on the floor and waits until the bees go in the box.
                                                    The man in the bee suit then places a cloth over the bees and secures it and takes them away.
                                                    Then says, 'Thats £25, thank you'
                                                    The swarm 25ft up is a daunting collection, personally I would not attempt it. The bees might stay there for about 24 hrs or so and then depart. I will explain what happens. The swarm leaves the hive and settles and while settled the swarm sends out scout bees. These look for a suitable home which is roughly 18" x 18" x 18". If they find one they come back and do a wiggle dance telling the direction and how far away it is. This may seem strange but the bees having the information from several scout bees then decide which home is best and then depart to it. While hanging in a swarm they are not dangerous and should not be disturbed or sprayed with water or any pesticide. Let nature take its course and all will be well.
                                                    Edited By Clive Hartland on 25/06/2015 20:53:47
                                                    #194927
                                                    Boiler Bri
                                                      @boilerbri
                                                      Just had a bbq n few beers. 🍻
                                                      Its been a great warm evening, for a change here in West Yorkshire
                                                      Bri
