What are these tools.
Home Forums Beginners questions What are these tools.
  • #204848
    Roger Hulett
      @rogerhulett83124
      I have tried to upload photographs but to no avail.I am afraid the technology is beyond me.
      I have two tools that I cannot identify. Each tool has the same appearance but different dimensions.;
      The shape is like a Xmas tree in a tub, (one is 60mm high the other 80mm.)
      The tub on the second one is 30mm x 10mm. There is a 3mm hole in the centre. The base of the triangle of the "tree" is 40mm. The top of the triangle of the tree(60mm) terminates in an upright section of 2mm x 10mm.
      The metal appears to be stainless steel and its thickness tapers from the "tub" end to the top (2.8mm to 1.2mm)
      Any help would be appreciated. Thankyou
      #7804
      Roger Hulett
        @rogerhulett83124
        #204849
        Jeff Dayman
          @jeffdayman43397
          To load photos you need to first make an album on this website, upload your pics to that, then click the photo icon in your posting to select the photo from your album and have it show in your post. (least that was the way it was last time I did it)
          #204852
          Roger Hulett
            @rogerhulett83124
            #204853
            Roger Hulett
              @rogerhulett83124
              Not very good,but we got there in the end !!!
              #204854
              pgk pgk
                @pgkpgk17461
                taper gauges?
                #204860
                David Clark 13
                  @davidclark13
                  Christmas tree label templates – cut around them?
                  #204883
                  Jeff Dayman
                    @jeffdayman43397
                    I'm only guessing, as I've never run into exactly this sort of template in industry, but here goes –
                    1. maybe templates for sign makers to cut out direction arrows on cardboard stencils?
                    2. maybe saw-angle-setting templates for a table saw, to set the saw fence for cutting wooden pickets of yard fences. If 4 cuts were made at same angle on the ends per template, a nice pyramid top for the pickets could be formed.
                    3. maybe templates for wooden wheel makers for spoke ends (or furniture makers, for chair legs)
                    4. maybe a template for patternmakers in a foundry for a commonly used pattern element like alignment pins or bars.
                    note: the holes look like they are for hanging on a nail, at least that is usually what the hole is for on templates.
                    note: pretty posh templates if made in stainless – most I have seen are wood, galvanized steel. or cardboard.
                    Who else wants a guess (or knows)?
                    #204895
                    Bazyle
                      @bazyle
                      They look more like scrap from stampings where the inverse was the required part. The thin spike on the top of the tree is typical as the clearance provided between the two parts being stamped out.
                      #204907
                      Jesse Hancock 1
                        @jessehancock1
                        Baz: Interesting. I wonder what the tiny circular punching was used for???
                        #204923
                        Roger Hulett
                          @rogerhulett83124
                          The metal itself is tapered,if it were scrap from stampings,what product would use tapered metal ? The metal at the "tub" end is thicker than the "Christmas tree fairy support" end. Could they be some sort of wedge ?
                          #204924
                          Bazyle
                            @bazyle
                            …….alignment in the press before punching.
                            #204935
                              Posted by Bazyle on 19/09/2015 11:18:28:
                              Can you please explain how you see that working ?
                              Thickness of material tapers from (2.8mm to 1.2mm)
                              Thanks
                              Bazyle
                                @bazyle
                                I wonder how you make a taper like that. Having done so it has to be rather important that the subsequent cutting is both the right way round, square, and the pattern is the right depth into the material. Also the taper may make the material move as one side is cut first. So pins would stop the operator putting it in wrong and hold it in place.
                                Being stainless it is perhaps something for food machinery, or for fancy trim, or gong to be hot.
                                Any machining marks?
                                #204982
                                J Hancock
                                  @jhancock95746
                                  Looks like the 1 in 3 and 1in 6 tapers used for setting the blower to petticoat location ?
                                  #204987
                                  Keith Petley
                                    @keithpetley53472
                                    Filling knife/scraper blades are tapered so that the blade gets thinner as it gets wider. Perhaps they are the scrap from stamping blanks for that sort of blade?
                                    For example **LINK**
                                    Keith
                                    #204998
                                    mark costello 1
                                      @markcostello1
                                      Blower to petticoat location? Is this an embarassing subject or does it mean something else?face 4
