Warco GH1236 won’t run
Home › Forums › General Questions › Warco GH1236 won’t run
  • #215212
    papflynn
      @papflynn
      My new lathe arrived. It will only run when I have the start button pressed. When I release the button it stops. The Warco faq says that it is due to the chuck guard and gear cover interlocks not closed but these are fine as the contactor energises when I operate the interlocks. Is there something silly that I’m overlooking?
      Paul
      Edited By papflynn on 05/12/2015 19:04:47
      #24260
      papflynn
        @papflynn
        #215215
        Emgee
          @emgee
          Hi Paul
          I would have thought with any of the safety interlocks broken the spindle should not run at all, not even "inch" in any direction.
          Emgee
          #215216
          Bazyle
            @bazyle
            Do you have a forward reverse handle on the right hand side of the apron that moves the bottom rod to operate a switch? the 'start' button may just prime it.
            edit: on a lot of these machines the emergency stop button gets it ready and puts power on the circuits but forward / reverse / off is selected by that lever on the apron. The go button on the headstock is just a jogging button not a master on.
            Edited By Bazyle on 05/12/2015 19:43:39
            #215217
            Andrew Entwistle
              @andrewentwistle
              Hi Paul,
              the start switch is a momentary jog switch so is working as intended. As Bazyle suggests to run continuously move the lever with the red ball knob, to the right of the carriage in the required direction (down for conventional forwards direction).
              Andrew.
              Edited By Andrew Entwistle on 05/12/2015 19:47:53
              #215218
              papflynn
                @papflynn
                Thanks Bayzle and Andrew thats all it was. Just proving to you all that that I am a real newbie. I’ll try not to suspect that there’s something wrong in future.
                Cheers.
