Warco DH6 vice
Warco DH6 vice
Home › Forums › Beginners questions › Warco DH6 vice
  • #108199
    Luke Graham
      @lukegraham30014
      Hi,
      I bought one of these vices (see http://www.warco.co.uk/vices–vice-jaws/117-milling-vice—dh6.html ), and used it a couple of times before something bad happened.
      At the end of the threaded rod, there is a keyway where the handle connects to turn it. The key appears to have ripped its way right through the rod metal! Has anyone ever seen anything similar? I can't believe I over-tightened, I didn't use a cheater bar or anything on it apart from the regular handle. Am I right to think this is just not a very well made vice? I know the price was low, but still… it doesn't seem fit for purpose.
      Thanks
      Luke
      #6507
      Luke Graham
        @lukegraham30014
        #108200
        Gray62
          @gray62
          I suggest you contact Warco direct before doing anything else, if it's still under warranty they will most likely just swap it out for a replacement.
          CB
          #108201
          NJH
            @njh
            Luke
            I agree with Coalburner – your first port of call is Warco. Explain the problem clearly ( and politely!)  – I've always found them very obliging.
            Cheers
            Norman
            Edited By NJH on 08/01/2013 14:00:16
            #108202
            MadMike
              @madmike
              Luke, opinion that you are seeking is not relevant. If you bought this new from Warco, or a Warco supplier, then go straight back to them and seek a replacement or refund.
              #108208
              Luke Graham
                @lukegraham30014
                Thanks guys, I'll take a photo when I get home tonight and email it to them so they can see what happened, and will ask for a replacement.
                #108222
                Lambton
                  @lambton
                  Always send faulty goods back to the supplier.
                  I am sure that Warco will be very obliging and will replace the vice immediately with an apology.
                  Like other suppliers of Far Eastern equipment their quality control system appears to be to supply items exactly as they receive them from the manufacturer and then react quickly to satisfy customers who complain. This way everyone believes the supplier to be very good. What they should really do is to exercise proper quality control over the supplier to prevent faulty items leaving the factory in the first place.
                  #108257
                  jason udall
                    @jasonudall57142
                    Though we all too often are ,the customer should not be doing the job of the quality/goods out inspecton department.
                    If defective / mis "labled" product is not brought to the suppliers attention then they cannot rectify and avoid that supplier ( to them ), or even know to check before dispatch…
                    We are also part of the problem/solution.
                    #116640
                    Luke Graham
                      @lukegraham30014
                      I just want to say that Kaye and Dolly from Warco sorted this out quickly and without fuss. The only reason it took so long is that I took ages to actually send it back.
                      With this in mind, I would happily recommend buying from Warco, because if there are problems, they will rectify them.
