Hi Robin.
I have owned a Warco VMC mill for around 17 years now, mine is a Taiwanese made version from 1997. A few years ago I fitted a used 1 HP Brooke Crompton three phase motor that I reconditioned, plus a new Inverter and Pendant control from Power Capacitors. The 1 HP motor has always been more than enough for this mill. The original single phase motor fitted was also 1 HP. I think current versions have a more powerful motor fitted.
It was a fairly easy, straightforward job that I should have done a lot earlier. It has transformed the machine from a bit of a vibrating rattler into a smooth and quiet machine tool with excellent speed control.
I have always liked the VMC type turret milling machines, probably why I have still got it after all these years. The current Chinese made VMC mills are a little heavier built than my Taiwanese made version, but are otherwise just about identical and are a good choice for the home workshop whether from Warco or the 626 from Chester.
Edited By Lathejack on 18/08/2015 23:56:02
Edited By Lathejack on 18/08/2015 23:59:06
Edited By Lathejack on 19/08/2015 00:00:07
