Using a Dividing head
Home › Forums › Help and Assistance! (Offered or Wanted) › Using a Dividing head
  • #636677
    Tony Martins
      @tonymartins59025
      Good morning all
      I have a need to machine a length of 1.5" dia x 1" TPI straight cut thread, my 1800 Student lathe is not man enough therefore I dreamed I may be able to use my indexing head on the mill and mill a spiral thread but as my indexing head is not a universal head I would like to know if it can easily be converted in some way to manually power the mill table by using a timing belt type drive or should I go back to sleep again. Any ideas will be much appreciated.
      Tony
      ABM
      #34187
      Tony Martins
        @tonymartins59025
        #636679
          Depends on how smooth the thread needs to be but it can simply be done in increments moving the table then rotating the work and depending on form you may need to make up a cutter.
          I have seen other lash ups where the drive to the dividing head or rotary table was disengaged and various belts and pullies linked to the table handwheel so work turned when the table was moved which all seem to work OK and probably better than trying to drive the table from the dividing head
          Edited By JasonB on 08/03/2023 11:39:57
          #636680
          John Haine
            @johnhaine32865
            Prof Chaddock recommended cutting the column thread for the Quorn using a powered milling spindle on the lathe carriage, and driving the headstock mandrel from the leadscrew using a handle on the leadscrew.
            #636692
            Martin Johnson 1
              @martinjohnson1
              Here is my set up for a steering box screw on a Tom Senior M1 and the usual Taiwan 6" rotary table:
              Cutting the steering screw.
              Sorry dont know how to do a hyperlink.
              Martin
              Edited By JasonB on 08/03/2023 13:13:53
              #636717
              Clive Foster
                @clivefoster55965
                Martin
                Cunning set up. Driving the rotary table directly via a chain of gears was, for me, a classic "D'oh obvious" now someone has shown me thing. Would work just as well with a spindexer too.
                Brilliant lateral thinking.
                Many professional dividing heads, like my Cincinnati copy Edgewick have a drive shaft provided for this sort of use. Cincinnati had whole bolt on change wheel bracket, gear set and cover assembly to use their heads on their mills. My dividing head came with couple of chain and sprocket assemblies that were used to connect it to a Bridgeport for, as I recall it, some sort of mould making work.
                #636725
                John P
                  @johnp77052
                  Without knowing what type of milling machine that you have or dividing head
                  it would be difficult to answer that question.
                  For example if the leadscrew on your mill was 8 tpi and the dividing head
                  was 40 to 1 ratio you would need to gear up from the leadscrew to the
                  dividing head at 5 to 1 .It is unlikely this could be done in one step
                  with a toothed belt as the pulley sizes will be large,some additional gearing
                  would probably be needed as well as a tumbler reversing for left and right
                  hand thread.
                  I have done here almost the same as what you are trying to do at 1.480" dia
                  and 3/4" pitch but with cnc which is a much easier solution as you can
                  get to any pitch with just a little number juggling.Cant remember what the slot width but was climb milled to finish leaving a perfectly finished thread.
                  #636750
                  Clive Foster
                    @clivefoster55965
                    John P
                    Martins method of directly driving a rotary table, spin-dexer or simple spindle seems much more appropriate than attempting to drive a dividing head via its normal worm and wheel.
                    Direct 1:1 drive will replicate the feedscrew pitch.
                    Coarser pitches will need the rotary drive stepped down in the same ratio as the feedscrew and desired pitch. So, for example, if the feedscrew is 8 tip and the desired pitch 1" then 8:1 step down will do the deed. It's unlikely that any ratio be large enough to be wildly impractical. Its the method I shall adopt should I ever need to do "figure 8" oiling grooves.
                    Admittedly producing a metric pitch on an imperial machine or imperial pitch on a metric machine will be tricky as the conversion gear(s) need to be arranged. Arranging temporary metric or imperial feedscrew using decent studding might be more attractive in that case. As Y-axis feed will not be needed once all is set up an external screw is feasible with the nut clamped to the Y dovetails.
