Please don't let's get unpleasant about this.
I did take everything in the spirit it was intended including being told, rather unflatteringly, I was 'clearly new to the game' and should read a book! (I've been studying and referring to Sparey's The Amateur Slave (sic) for at least 10 years along with many others including Hall and Using the Small Lathe, and will continue to do so.)
The problem, as far as I can see, was the revolving centre. I was generously given it by a retired professional engineer who never claimed it was perfect. However, which I didn't realize, it was worn out and I will buy a new one. As I said earlier, when I supported with a brand new (because it's not something you use everyday) revolving scroll chuck in the tailstock my problems were largely solved.
The collet, the arbor and the clamping nut were virtually new and clean, as I pride myself on keeping my tools that way.
It was a mistake to work the compound and not the carriage, but I was addressing a space and logistics issue. When I did use the carriage, and was thus able to engage automatic feed, the finish was transformed. Any taper or lack of parallelism that is there now (and we are not looking for tenths of thous here – to loosely quote Brown & Sharpe in Instructions for Young Engineers: 'don't spend hours agonizing over a dimension that's not critical'
is down, I feel to the configuration. I.e don't work shank to shank, which means a pass of around 100mm with cut off allowances on a diameter of less than 8mm, but work head to head so the pass is half that and much less likely to deflect the work.
I'm happy. So let's not be saying people are infantile!
Martyn (with a 'y'
PS Liked the photo of the double-waisted bolts. Need one like that for the radius rod anchorage. Wonder how it's done?!
