Unkown small lathe
Unkown small lathe
Home › Forums › Manual machine tools › Unkown small lathe
  • #458049
    Grindstone Cowboy
      @grindstonecowboy
      Hi folks, hoping somebody might be able to identify this lathe I recently inherited. It has absolutely no makers marks that I can see, nor any serial numbers. Slowly working my way through each manufacturer on lathes.co.uk but it's a long job!
      It appears to be simply, but sturdily made, there don't appear to be adjustable gibs on the slides.
      Thanks for any suggestions.
      (edited to get the text before the pictures…)
      Edited By Grindstone Cowboy on 18/03/2020 20:55:22
      #13803
      Grindstone Cowboy
        @grindstonecowboy
        Can anyone help to identify this lathe?
        #458077
        Pete.
          @pete-2
          Looks like a nice old machine that hasn't been abused like so many of these old obscure little lathes, I can't help you with the model unfortunately.
          When you start researching old machine tools like this, it's shocking just how much industry we used have making so many tools etc, so many small obscure companies making machinery in the first half of the 1900's.
          #458078
          Steviegtr
            @steviegtr
            Posted by Pete. on 18/03/2020 22:54:08:
            Makes you wonder now. If all the large companies go under. Lots of new small enterprise may spring up.
            Steve.
            #458079
            Ady1
              @ady1
              Certainly built to a price with the minimum of metal possible
              It's not like pouring big lumps of cast iron back in "-t' good old days-" was expensive
              The expense was in the level of machining in the product, but this one has quite careful, almost fragile, castings
              Edited By Ady1 on 18/03/2020 23:44:58
              #458080
              Grindstone Cowboy
                @grindstonecowboy
                Thanks Pete – yes, it appears to be in excellent condition for it's age, with just a little rust on the chuck and on one spot on the bed, and no visible wear on the bed or leadscrew. I'll probably have to sell it as I now have six lathes and very little space left due to the passing of a close friend and acquiring the entire contents of his garage. But deciding what has to go is difficult.
                There's also a hand shaper that I'm trying to identify, but it is in bits at the moment – I think it could be a Perfecto (there's a lot less shapers to look through on lathes.co.uk) – but hopefully it's all there so it can be got back into working order.
                #458082
                Hopper
                  @hopper
                  You might try sending some pics to Tony at Lathes.co.uk if you can't find it on his site, He may be able to identify it.
                  Interesting old machine, especially the combination top/cross slide set up. Good to see the dog clutch on the leadscrew. Very handy and something Myford should have fitted to the ML7 etc.
                  #458084
                  Grindstone Cowboy
                    @grindstonecowboy
                    Hi Ady
                    Yes, it's neat little machine, but surprisingly heavy – the bed has (to my inexperienced eye at least) plenty of stiffening ribs underneath and I'm pretty sure it would cope with the type of work it was designed for. One interesting part is the handle for the dog clutch on the leadscrew – the castellated nuts holding the handle on put me in mind of an old lawnmower I have, and it almost looks like an afterthought.
                    #458085
                    Grindstone Cowboy
                      @grindstonecowboy
                      Thanks Hopper, I'll get some better pictures from all angles and see what Tony can do. The top slide swivels 360 degrees, the handwheel on it looks like something I could make myself – very plain, and cheap-looking when compared with the main castings, so it may not be original.
                      #458099
                      Redsetter
                        @redsetter
                        Interestingly it seems to have a right handed leadscrew. Also packing blocks under the headstock, so it may be somewhat modified from the original.
