Uni Project Help
Uni Project Help
  • #33558
    Dan Baines
      @danbaines39866
      #459786
      Dan Baines
        @danbaines39866
        Due to the current situation in the UK my university workshop has had to shut and I didn't manage to get a part finished on the lathe in time. If anyone would be able to help me change the length and diameter of the shaft of the part shown in the images attached I'd be massively grateful! Please see the attached images for dimensions (the new shaft does not need a thread).
        I'd be happy to arrange a courier to pick up and deliver the part both ways.
        Many thanks,
        Dan
        #459814
        David George 1
          @davidgeorge1
          Where are you as a local person could do that sort of mod quite easily.
          David
          #459823
          noel shelley
            @noelshelley55608
            As the above says ! Your welcome to use my gear . Though we're in difficult time so not sure how it could be done.
            Noel
            #459838
            Dan Baines
              @danbaines39866
              Thanks for the replies guys. I'm in Leicester but obviously not leaving the house at the moment. I'd organise a courier to pick up and drop off the part anywhere in the UK and for the return if someone could help.
              Many thanks,
              Dan
              #459853
              Former Member
                @formermember19781
                #459860
                Dan Baines
                  @danbaines39866
                  Posted by Bill Chugg on 26/03/2020 15:05:42:
                  Is it steel or ali and what are the pre maching dimensions please?
                  Bill
                  Edited By Bill Chugg on 26/03/2020 15:06:52
                  Aluminium and the pre-machining shaft dimensions are roughly 30mm length and 8mm diameter. The base has a diameter of 25mm and height of 9mm however this does not need to be changed. Dimensions may be slightly inaccurate, all I have to measure is a ruler!
                  Dan
                  #459862
                  Former Member
                    @formermember32069
                    #459863
                    Former Member
                      @formermember19781
                      #459865
                      Dan Baines
                        @danbaines39866
                        Posted by Barrie Lever on 26/03/2020 15:22:10:
                        Hello Dan
                        I can do that job for you if no one has picked it up already, it is not even 20 minutes work.
                        Email me on [email protected]
                        Best Regards
                        Barrie
                        Thanks Barrie. I'll send you an email now.
                        #459867
                        Dan Baines
                          @danbaines39866
                          Posted by Bill Chugg on 26/03/2020 15:23:27:
                          Thanks reply – does it have to be a good fit with another part ,oris it a stand alone item ?
                          Bill
                          The shaft mounts onto the back of a motor to allow for an encoder to track it's position. The encoder disk will be mounted on the shaft.
                          Dan
