Bob –
The lifting injector works as an e –jector first – the steam jet entering the combining-cone produces a partial vacuum to draw the water up into the device. The air is expelled through the overflow.
Once the water is there it will continue to work almost as both in and e– jector modes at once.
Their internals are much the same whether used lifting or gravity-fed, but I don’t think all are necessarily good at sucking up the water to start with. DAG Brown designs his so they will lift to an appreciable head even though usually used on locomotives or on traction-engine bunker sides.
If the injector can lift sufficiently high, it does not need a water-valve if placed above the tank’s top water-level.
Some commercial, full-size injectors were made with a single control that opened the water inlet then the steam in a single turn of the handle. These could work in lifting or gravity-fed installations. The valves were worked by very coarse threads and appear designed so the steam could be adjusted without affecting the water flow.
Baz –
Horizontal or vertical? Doesn’t really matter functionally. They differ markedly in layout so the overflow valve is always helped by gravity. Horizontal ones are common on most locomotives to suit being low down under the footplate, and the disposition of the in and out pipes. Vertical injectors seem fairly common on road steam vehicles, but the only rule for the choice on a model is fidelity to prototype.
Full-size injectors commonly use split, hinged combining-cones to give the overflow action, but this would be problematical in miniature, hence using ball-valves.
Duncan –
That a particular injector will operate in lifting mode doesn’t mean all will, nor that it has to. On most traction-engines and locomotives the device is located low down and gravity-fed.
This gives the advantage Bazyle describes, that the injector starts cold. The steam has to condense extremely rapidly in the combining-cone, and a hot injector or feed-water hampers that. It does surprise me that backhead-mounted, lifting injectors, used on some applications, work at all!
Injectors should not “dribble” water when working in optimum conditions. Turn the water on fully on a gravity-fed device and I would expect a full, steady overflow stream, though smaller than the open feed-pipe would pass. Once the magick Physics is under way, perhaps with a bit of tickling of the steam or water valve or both, the overflow should not emit anything.
The club’s loco on which I learnt to drive miniatures, was a 5″ g. Maid of Kent (curiously named … Athens) whose injector chirruped like an excited guinea-pig. As it was feeding the boiler I assumed injectors are natural singers. It was years before I learnt a good little injector is seen and not heard. The chirping indicates an inwards air-leak, commonly from a tender feed-bag that is just simple hose pushed onto plain pipe, as the Athenian lass’ was.*
For either problem, refer to the chaper on fault finding in D.A.G. Brown’s treatise.
*was? I hope the “lass” is still running, wherever she is now!
