All good suggestions/info above.
All I can add is my experience when I started turning metal, some 35 years ago.
My first experience of a lathe was with a very old machine that actually worked, even though in a poor condition visually. I turned down a pin for a friend in order to get over an urgent problem.
I later bought a new chinese lathe – rather than a second hand lathe – because I thought it would readily find my deficiencies rather than being due to the lathe. How wrong I was! I later purchased a cheap Raglan Mkll, which served me well (when I finally got round to installing it).
I eventually bought a good Raglan 5” which, I am sure, will see me out.
Practice metals were mainly aluminium round bar from a college with an engineering department and steel from the scrap bin of a small agricultural business. I’ve never used free-cutting steel (containing Lead) because I often needed to weld bits together. I am lucky enough to have a small kiln, so am able to anneal small steel or cast iron parts, if necessary.
I don’t actually make models as my hobbies involved repairs/restoration at a scale of twelve inches to the foot!
BTW, given suitable grades of Aluminium, the main cause of metal sticking to the cutter is excessive heat, often caused by a poorly sharpened cutter. Sharp cutters and good cooling with paraffin based lube/cooling usually gets over that problem.🙂
Good advice here. I started with a Chinese mini lathe and it took me about a year of adjusting, fettling, and some focused upgrades to get it to comfortably cut without chatter, and be able to reliably hit dimensions.
I then bought a Taiwanese Warco 9×20 (Warco 918) and after doing the donut mod, it’s been good as gold. Recently picked up a 1HP 3PH motor and VFD from Inverter Drive Supermarket, so that’s on the backlog and I’m going to add a reverse tumbler when I get round to it.
Just to mention EN1A is free cutting and doesn’t have lead. It’s sulphurised, which helps the machinability. Still can’t weld it, though.
To be fair free cutting steels are generally poor weld candidates. Leaded steels as you say are pretty much unweldable, but the sulphurised ones are very tricky. Something to do with sulphur having a low melting point.
