Too shiney and new
Too shiney and new
Home › Forums › General Questions › Too shiney and new
  • #22698
    Eric Cox
      @ericcox50497
      #124082
      Eric Cox
        @ericcox50497
        Why do builders finish their locomotives as if they have just come out of the paint shop at Crewe.
        I've yet to see a loco that is weathered and worn, far more realistic than the shiney and new showcase models that people build.
        #124083
        John Stevenson 1
          @johnstevenson1
          For the same reason that they won't drill a hole in their Myford to fasten a much needed piece of equipment ?
          #124084
          Martin Kyte
            @martinkyte99762
            I can understand the desire to put a perfect finish on the object you have spent so much time creating. To distress the finished article really seems to go against all you have bee trying to acheive for all those hours (years). That said the best models Iv'e seen and certainly the ones I look at for longest at shows are the one where the model engineer has done just that. Not making it look battered about but really trying to understand the loco or traction engine in use. Foot steps and hand hold worn shiny by usage of crews odd corners uncleaned where it's difficult to get a rag in. Paint knocked of on corners that get hit by shovels, oil cans or lumps of coal and the detritus of daily use. These are the things that make a model come alive to me… Anyone else feel this way?
            #124086
            Geoff Rogers
              @geoffrogers81118
              bright and shiney so it can go back into the house after running, I suppose.
              I have drilled holes in my Myford and cut/bent spanners for restricted access.
              #124087
              Ady1
                @ady1
                People who have the patience and the attention span which allows them to build complicated things often also have a thing about attention to detail
                So mucking something up goes against the grain
                #124088
                Eric Cox
                  @ericcox50497
                  "People who have the patience and the attention span which allows them to build complicated things often also have a thing about attention to detail"
                  Surely simulated rust around the chimney base or lime scale around the steam dome is just as much detail and more accurate than a highly polished back head or mirror finished paint job.
                  Edited By Eric Cox on 08/07/2013 10:00:24
                  #124089
                  NJH
                    @njh
                    Surely if they start off shiney and new they will "mature" to " weathered and worn" over time? Whenever I've bought a new ( or "new" S/H) car it starts off shiney and new and I try to keep it looking like that. In a very short time I give up and it looks "comfortably used". Why should models be any different? I've never found a need to simulate rust as that seems to happen automatically.sad
                    Norman
                    #124090
                      The methods used to weather models are not that durable so would be hard to keep intact on a loco that was used regularly. I've seen it done on other models such as this hit & miss engine and this guy did WD colours on his TE though not covered in mud
                      #124097
                      Bazyle
                        @bazyle
                        It is also 'custom and practice'. In model railways and model boats it is a recognised option to produce a weathered model and be duly credited for the achievement in exhibitions. In ME it simply isn't normal. Perhaps due to the fact that often full size they did endevour to roll a loco out of the shops in imaculate contidion (mainline not shunter) or a Victorian waterworks would be made as a marbled hall with a polished brass beam engine inside.
                        Just look at the equivalent today – do Airbus deliver you a new jet with pre-applied oil leaks?
                        #124099
                        Anonymous
                          Posted by Bazyle on 08/07/2013 11:37:13:
                          Sadly if it's got Rolls Royce engines then the answer is probably yes. sad
                          #124101
                          Hopper
                            @hopper
                            Perhaps the same reason some people will take a well-preserved, running, vintage motorbike or car and "restore" it with a standard of chrome, paint and polished aluminium even brighter and shinier than it left the factory with.
                            Some people just like to make bright and shiny things. Others like them worn and comfortable.
                            #124104
                            MICHAEL WILLIAMS
                              @michaelwilliams41215
                              Hi Eric ,
                              Not so much why do builders choose to finish their engines all bright and shiny but more why do small engines look disproportionately shiny and bright relative to real engines .
                              This is mostly down to various scaling and real and perceived optical effects model v full size ..
                              These include :
                              The relative coarseness of finish on bright parts – especially things like con rods and flywheel rims
                              The relative matt / gloss levels of paint .
                              The different appearance of large areas of any chosen finish against small areas of same finish .
                              Viewing distance and viewing subtended angle .
                              Play of light and refections of parts and surrounding scenery .
                              That's a few first thoughts but several more effects are probably involved .
                              Regards ,
                              MikeW
                              Edited By MICHAEL WILLIAMS on 08/07/2013 13:20:36
                              #124107
                              NJH
                                @njh
                                Maybe Mike but if you've spent months (nay – years! – or even years and years) working away at something maybe you prefer it to LOOK nice at the end – I know I do. Shiny always appeals to me more that dull.
                                If you are driven by the need to compete for prizes and "authenticity" gains extra points then I guess you have to follow that path but how many folk ARE driven by competition? I do this for "ME" and if I'm satisfied then thats what I seek – which brings me back to shiney!
                                Would I drill a hole in my Myford? – I'd much rather not – so I'd seek a workaround if possible. When you do stuff for a living like John S then the drivers are different.
                                Norman
                                #124436
                                nigel jones 5
                                  @nigeljones5
                                  mine looks well weathered and I only just finished it…looks like it was painted by an idiot…..ah!!
                                  #124574
                                  Sub Mandrel
                                    @submandrel
                                    I prefer models to look at least vaguely like the real think Boatbuilders are the worst offenders – brass railing replace rusty, may-times painted iron with a texture like 'The Thing' from the Fantatstic Four.
                                    My shunter looked like a toy as originally painted, I had to matt it down, but I still fee like adding 'rust'. It also showed up the tiniest flaws, while with a matt finish they just look like part of teh 'character'. Excuse the poor colour balance on these shots.
                                    Before:
                                    Three-quarter view
                                    After:
                                    Still Finished
                                    #124578
                                    jason udall
                                      @jasonudall57142
                                      Can’t paint for toffee.
                                      Would only paint for functional benifit. Admire the skills shown on pristine effect and again in weathered effect. Remember the praise that the “Lived in” look of starwars models attracted in the day
                                      But you models your choice. Good luck to you
                                      The
