TaeguTec Inserts?
TaeguTec Inserts?
Home › Forums › General Questions › TaeguTec Inserts?
  • #215005
    Roger Hulett
      @rogerhulett83124
      Has anyone used these "gold rush coating" inserts. Advertised on Fleabay.
      Very cheap. Seller has Zero rating.
      Sounds a bit dodgy…..any comments???
      #24255
      Roger Hulett
        @rogerhulett83124
        #215012
          Depends what seller you look at one has 2600 feedbacks 99.7% positive
          #215016
          Raymond Anderson
            @raymondanderson34407
            I use Taegu Tec inserts regularly ,and they are top class. Both the " Gold Rush " ones and the uncoated
            high rake ones. They also have a long lasting cutting edge Taegu Tec and Walter are be MY 2 favourite brands.
            I also get all My Taegu Tec inserts from ebay through Tooling Solutions. First rate
            Raymond.
            #215043
            Roger Head
              @rogerhead16992
              I've been using TaeguTec inserts for almost 10 years, quite happy with them. The hi-rake polished ones, intended for aluminium, are also good for very fine finishing cuts on steel.
              Roger
