SX2 mill – Is it man enough for :-
Home Forums Workshop Tools and Tooling SX2 mill – Is it man enough for :-
  • #17514
    Nick_G
      @nick_g
      #164784
      Nick_G
        @nick_g
        Is the Sieg SX2 milling machine sturdy enough for constructing models similar in size to the Stuart range.
        Or shall I save some more coins and go for a SX3.?
        Any general points on the machine, both positive and negative I would also be grateful for.
        Edit :- MT3 or R8 version.?
        Cheers, Nick
        Edited By Nick_G on 27/09/2014 12:04:11
        #164789
          I would probably go X3 if you have the cash and room, simply because it is a bigger machine and therefore will always be a bit more solid while still being a benchtop machine.
          I chose X2 over X1 for the above reasons, and got one of AAc's first batch of X2s. It was not as rigid as I expected, but since adding belt drive, angular contact bearings and stiffening the column I have been very happy with it.
          If you want an X2 consider the solid column SX2 machine from Arc, as it also has a brushless motor with belt drive and bigger table.
          Tasks I have done on mine include:
          Milling the frames and stretchers, connecting rods and spoked wheels for a 3 1/2" gauge loco.
          Cutting 20DP gears in 1/4" steel blanks in one pass.
          Making a dovetailed QCTP and tooldholder.0
          MT3 if you want compatibility with your lathe spindle, if not… it's up to you.
          Edited By Neil Wyatt on 27/09/2014 13:06:23
          #164791
          John Stevenson 1
            @johnstevenson1
            Just a note here, the various X2's are different animals depending who you buy off. They vary on motor size, table size and column design.
            The SX2 is a totally different animal. The old DC drive is replaced by a brushless motor drive, table sizes are larger and it has a fixed column for rigidity.
            Very easy to confuse X2 with SX2
            #164801
            Russ B
              @russb
              I bought the SX1 from ArcEuro with the nice big 400 table and in the end I removed the tilting column and made an adaptor plate to fit the rigid column – it was a vast improvement and transformed the machine, ultimately the little 150w motor limited everything and as it was CNC'd the software was aiming for higher feeds and speeds than it could cope with, I had input the machines power and max spindle speed, plus an overall factor but it just resulted in the software generating lots of shallow passes which dulled the tools or trying to take fewer deep cuts very slowly which had a similar effect.
              I think the wider rigid column combined with the large table from the X1 that Arc offer on their X2P offers a pretty capable machine for £600 – I don't think there is a machine on the market that can better it.
              the SX3 is more than double that price, and throws it in to tough competition from machines like the Warco WM18/SPG 2217-30 LV/AMA30
              Perhaps a middle ground could be struck with the Chester 20V,Amadeal AMA25/Warco WM16 – all these machines benefit from taper gib strips and slightly beefier tables – that's where the extra £200 goes I do remember getting so fed up trying to adjust the gibs on my SX1L that I remade them out of brass so I could just run them a bit tight and they'd still glide – previously they just seemed to loose or lock solid – I even remade the adjusting screws with ball ends and cleaned up the cups on the original strip but it didn't really help.
              I don't think I'd let that put me off on the X2P at £600 it seems suitably priced, but I would hope the system worked better on the SX3 as I notice they don't seem to have tapered strips either -hopefully they are a bit thicker though – at more than double the cost, I'd hope so but I notice off the shelf gib upgrades are/were available a couple of years ago which is very telling if you ask me.
              I like to get a copy of the manual or service guide from the sellers and flick through them to see how they're made to get a few ideas about quality and strength.
              Edited By Russ B on 27/09/2014 14:57:07
              Edited By Russ B on 27/09/2014 14:58:32
              #164804
              Nick_G
                @nick_g
                Thanks for the replies guy's laugh
                It was the SX2P variant I was considering Vs the SX3
                I have actually just popped down to the Warrington branch of Axminster to have a hands on nosey at them both. (yes I do know their 2 variant is not the same as the SX2P) But I thought it would give me some food for thought. ( I will be purchasing from ARC anyway though yes)
                They are even taking the columns aside totally different critters though. The SX3 is not just a bigger machine it also seems to have a better feel and more finesse.
                I wonder if Keatan likes homemade cake.??? surprise – My housemate spends her spare time making wonderful creations. If I went to ARC to pick up my choice I could trade cake for extra metal goodies. winkwinkwink
                Cheers, Nick
                #164817
                Ketan Swali
                  @ketanswali79440
                  Nick,
                  Yes, any cake is great (without icing)
                  Ketan
                  #164819
                  Ketan Swali
                    @ketanswali79440
                    Posted by Russ B on 27/09/2014 14:55:04:
                    Just out of curiosity Russ, which CNC CAM software were you using when you put in the machines power and max spindle speed?
                    Thanks, Ketan
                    #164824
                    Russ B
                      @russb
                      Ketan PM sent to keep things on topic here
                      – pet hate of mine cheeky
                      #164827
                        Really depends on which of the Stuart range you are thinking of doing. the smaller engines and those that use the 1" bore x 2" stroke cylinder can all be done on quite light mills for example I did my beam with a Unimat 3 mill though for a couple of bits like the base I did have it fitted to the back of a larger lathe.
                        Its only if you are thinking of the larger ones like the No1 and Major Beam that you may want to go for a heavier mill but as you have a decent sized lathe there is nothing to stop you using that for some of the parts as many did for all the milling in the early days.
                        J
                        #164829
                        Nick_G
                          @nick_g
                          Posted by Russ B on 27/09/2014 20:24:01:
                          You are only saying that because you have not been offered cake.! devil laugh
                          Nick
