I have an older S7, from 1954, which has the original aluminium pulleys. As Dennis says, Myford have always used motors with a 5/8" shaft, so it has been changed at some time – not surprisingly- I also have a more modern motor fitted, but still with a 5/8" shaft, as this is the bore size of the original pulley.
My later S7, from 1967, still has the aluminium pulley.
The diameters of the original motor pulley are 45/16" (four and five sixteenths),so yours is a bit small, and 17/8" (one and seven eighths), as I said the bore is 5/8".
If you can get pulleys the right size you can always sleeve the bore to fit your motor – or fill it up and re-bore.
Also as Dennis says, the belt sections are different, the motor to countershaft being slimmer than the countershaft to headstock.
Hope this helps
Phil
Edited By Robbo on 08/09/2012 22:29:56
