Steam lubricators
Steam lubricators
Home › Forums › General Questions › Steam lubricators
  • #22554
    Kevin Bennett
      @kevinbennett25223
      Steam lubricators stuart 10V
      #115596
      Kevin Bennett
        @kevinbennett25223
        hi Guys i am looking for drawings for small steam lubricator for a Stuart 10V as i want to make one instead of buying one.
        i have looked around with no luck if they are in any back issues of ME i cannot access as i only get MEW i would be very grateful for any help
        Thanks Kevin.
        Edited By Kevin Bennett on 29/03/2013 12:52:40
        #115599
        MichaelR
          @michaelr
          For details for a displacement lubricator see here
          #115605
          Sub Mandrel
            @submandrel
            Hi Kevin,
            From memory, teh one I made for my 10V is a drilled out 2" piece of 1/2" brass rod. Cross hole a bit down from the top with piece of ordinary steam pipe across it and probably a 1mm/No.60 hole, silver soldered in.
            0BA hole in the bottom with a plug, lid silver sodlered on an 0Ba plug on top (I didn't have any bigger taps/dies in those days).
            Doing it again I would make the top plug bigger and drill a smaller hole in the steam pipe as the oil flow is a bit too generous.
            Kevin Bennett
              @kevinbennett25223
              Hi thanks for that i will have a go and see what happens i do have some very small drils
              all the best Kevin
              Edited By Kevin Bennett on 29/03/2013 17:16:11
              #115681
              Ian S C
                @iansc
                Neil, I made one for a little (1/4" bore, 3/8" st)wobbler, it's about half the size of yours, I had similar trouble with over oiling, so I put a bit of wire in the hole.
                Kevin, I made a flat bit from an old sewing machine needle for my second oiler, not sure the size, but less than .5 mm. Ian S C
                #115686
                Sub Mandrel
                  @submandrel
                  Ian,
                  that's a good idea!
