spring loadede clacks
Home Forums Beginners questions spring loadede clacks
  • #200298
    nigel jones 5
      @nigeljones5
      ive just finished 2 nitrile ball clacks fot my loco but saw spring loaded ones on (i think) pansy – anyone tried this type??
      #7750
      nigel jones 5
        @nigeljones5
        #200843
        nigel jones 5
          @nigeljones5
          ping!
          #200845
          Windy
            @windy30762
            Would like to know if spring loaded OK on laid over stainless ball valve pump and burner feed pumps on the flash steamer.
            #200851
            Clive Hartland
              @clivehartland94829
              Is the spring to stop them ' Fluttering' that's a nice word aint it! Relying on back pressure may not be enough so it needs spring loading?
              #200867
              Chris Gunn
                @chrisgunn36534
                I have always used a light spring for my traction engine clacks, albeit a slightly bigger size than for a 5" loco. I felt that the spring helped to keep the ball under control over the top of the incoming port, and stopping it moving sideways and blocking the outgoing port. However Gordon Smith wrote an article in January this year on making clacks without a spring, keeping the ball above the hole with a sleeve, without a spring. This is worth a look.
                Chris Gunn
                #200872
                julian atkins
                  @julianatkins58923
                  hi nigel,
                  ive never come across spring loaded check valves on miniature steam locos and certainly not by LBSC other than for mechanical lubricator pumps.
                  a properly made steam check valve shouldnt need a spring. ive got a few fitted of 'inline' type in the horizontal position. they have never caused any problems.
                  cheers,
                  julian
                  #201013
                  nigel jones 5
                    @nigeljones5
                    thanks all – I have made lots of clacks over the years, none with a spring and all worked well – seems like its a mixed bag
