spindle thread
spindle thread
Home Forums General Questions spindle thread
  • #27940
    john brown 17
      @johnbrown17
      #524769
      john brown 17
        @johnbrown17
        Has any one come across a lathe with a 1 27/64" x 8tpi thread on the spindle its on a very old IXl lathe , l did think it was 1 3/8" but trying that size its to loose,be nice to have a new chuck for it when the old girl is restored.
        john
        #524773
        DC31k
          @dc31k
          Surely the chuck does not use the threads alone for location. Does it not have a register inboard of the threads? The register size and fit of the chuck to that register is way more important than loose or tight threads. The threads do not want to be too tight lest they try to influence the register.
          #524777
          Oldiron
            @oldiron
            Is it IXl or Zyto branded? Try here for lots of info IX1-Zyto
            regards
            #524779
            colin hawes
              @colinhawes85982
              DC31k is correct; the thread will be 1 3/8 x 8 and it's job is to push the chuck onto the register which IS a close fit. Colin
              #524782
              David George 1
                @davidgeorge1
                Could it be 36mm x 3mm pitch as they were made in Germany in the main. Have a look at lathes.co.uk
                David
                #524788
                john brown 17
                  @johnbrown17
                  Thanks for that lathe link ,it looks like l have got a 6" IXL AKT gap bed lathe ,but could not se on the site about the spindle thread size,yes do get the thread an register side buit 1 3/8 " is really loose .
                  john
                  #524789
                  Pete Rimmer
                    @peterimmer30576
                    I don't find it unusual at all. I had to make a backplate for a IXL dividing head last week which was 1-41/64" – 11tpi
                    #524820
                    DC31k
                      @dc31k
                      Posted by colin hawes on 04/02/2021 16:47:44:
                      If you have understood my post as saying this, then I am sorry that I did not write more clearly.
                      A simple OD measurement of the register would give a more reliable indicator of the thread size than an OD measurement over the thread crests. If the register is 1 3/8", then it would be difficult for the thread to be 1 27/64" (27/64" is bigger than 3/8" so the register would not go over the male thread).
                      If the register is close to 1 27/64", then further investigation is needed, including David's metric possibility. One way may be to do a three wire measurement of the thread. There is a good online calculator somewhere for this, whose address has been posted here before. It will tell you the best size wires, but will also give you the measurement if you input the wires you are using. This means you can use three drill shanks, three drill blanks or three bits of silver steel or whatever you have to hand that is close.
                      On further reflection, I am wondering how a loose fit of a 1 3/8" (female?) thread leads to the supposition that the mating (male, spindle?) thread is 1 27/64", a bigger size. Surely the only way to get the two threads to mate at all is some gender reversal?
                      #524828
                      john brown 17
                        @johnbrown17
                        Many thanks for your help ,being honest it would have nice to get a back plate etc already made,and not keep hiding under the stairs when it comes to screw cutting ,but my mentor friend and his side kick have given me the push to do it , and l do have a chuck that fits the lathe ,so will make a dummy spindle and take good measurements from the spindle when its on the bench and go for it .
                        john
