Socket set sizes
Socket set sizes
Home Forums General Questions Socket set sizes
  • #597358
    Stephen Follows
      @stephenfollows82099
      I have some sockets that were given to me. I thought they were AF sizes but they're not. The 7/16" fits a 1/4" whitworth nut. (This is the only nut size I have that fits one of the sockets). I cannot find any charts that gives 1/4"Whit = 7/16" something. Any Ideas?
      #28697
      Stephen Follows
        Cannot identify sockets
        #597359
        Mike Poole
          @mikepoole82104
          1/4 Whit head size is .445” , 7/16 AF is .4373” and 11mm AF is .433”. They can often fit each other if the tolerance on socket and nut are not too tight.
          #597362
          Stephen Follows
            Looking at them again I think they're probably AF. I have a mixed set with some missing. Think a previous owner must have used the box for a lot of loose sockets he had! I have BSW, metric and AF in one box.
            #597420
            Howard Lewis
              @howardlewis46836
              Are the sockets too badly rusted for any identification marks to be visible?
              Stating the painfully obvious, using the wrong socket to slacken a hexagon fastener, which is very tight, can result in the corners being damaged or removed. The socket might even split!
              Depending up on the age of the sockets, if of recent vintage, they might be Metrinch or Flank Drive sockets, (identifiable by the "flats" not being, but curved ).
              Metrinch sockets and ring spanners will drive, Whit, AF or Metric fasteners, sometimes where a conventional socket of that type and size will not.
              Once you have identified each socket, accurately, it may be worth engraving each one to clarify the size and application
