Hi, you don’t say if it’s the fuse in the plug top, or the fuse in the output of the transformer. If it blows with nothing plugged into the transformer output, then it’s quite possible the transformer is at fault. If it blows when the saw is used, it maybe that the load is too high for the transformer output, or it’s a cheap one and suffers from that what Malcolm has said. I’ve used 110 volt site transformers virtually all my working life, from small ones to very large ones of different makes, and I’ve two 2kw ones, a 3kw one and a 5kw one. and I’ve only ever know a fuse to blow very occasionally, and that’s while it was in use, and due to the fuse just giving up due to its age. I have never known one to blow during switching the power on to the transformer, and never when after replacing a blown one. The output power from the transformer should be capable to deliver more the the in rush of whatever is being used on it.
Regards Nick.
