Sieg super c3
Sieg super c3
Home › Forums › General Questions › Sieg super c3
  • #182038
    Jack C
      @jackc59137
      So I went and purchased the sieg super c3 from Arc and what a great lathe! Have worked on large lathes in industry work and wasnt expecting such quality for the price. Ian was a great help in ordering the lathe and after the initial strip down and clean up the lathe is great!
      Completed stripped it down and fitted the metal gears, brass gibs and stoned down the running surfaces for the slides and they are running very smooth!
      Ive turned using the one hss tool I had bought home from work that fit the small tool post and have now ordered some indexable tip tools from Glanze and just awaiting their delivery! In the meantime Im looking to strip down the motor/ spindle and fit the taper roller bearings as I can see everybody boasts at what an improvement this provides!
      My questions are…
      1) I have no experience on bearings, and nowhere specifically states how many are to be fitted so do I need to buy 2 of the taper roller bearings or 1? (Probably a stupid question I know)
      2) does anybody have any experience of fitting these and do you need any specific tools? I have access to a 2nd lathe at work and also a press so is this all I will need?
      3) How do I "preload" a bearing?
      Thankyou to those who can actually be bothered to read this far wink and an even bigger thankyou to those who are able to answer!
      #23753
      Jack C
        @jackc59137
        #182039
        Robbo
          @robbo
          Jack,
          If you look on the ArcEuroTrade website (arceurotrade.co.uk) under "projects and articles", almost the last thing in the index, you will find some help in various jobs on the Seig lathes, including the C3/Super C3.
          Phil
          #182043
          John Stevenson 1
            @johnstevenson1
            Two bearings
            #182137
            Jack C
              @jackc59137
              Thankyou Robbo and John, I have looked at the projects and articles page but still, to me, considering I have never fitted bearings before the guide seems a little brief? sad I just wanted to see if anyone here has done the modification and can just give me a few pointers really?
              Ill go ahead and order the 2 then cheers John, and if no one has any more info I'll just try and give it a go haha!
              #182155
              John Rudd
                @johnrudd16576
                Jack,
                I sent you a message…….
                #182169
                Robbo
                  @robbo
                  Jack,
                  There was an article about this in a MEW in 2008. I have sent you a message about it.
                  Phil
