Sieg SC3 CLUNK and no go
Home › Forums › Manual machine tools › Sieg SC3 CLUNK and no go
Viewing 15 posts - 1 through 15 (of 15 total)
  • #505823
    Mark Rea
      @markrea67084
      Hi guys. When i start the chuck on my sieg SC3 i get a clunk noise, the chuck kicks but nothing else happens. It started as i was drilling a 6mm hole in some steel bar, it went clunk and stopped. Turned it off and back on and it started, ran a couple of minutes and did it again. Now it just goes clunk when i turn the speed control to start the chuck. I always use the speed control knob to stop and start the chuck. Anyone got any ideas?
      Only had it a few weeks and am loving it, it is a pretty good machine. Hope you guys can help again.
      #14077
      Mark Rea
        @markrea67084
        #505833
        HOWARDT
          @howardt
          I have had mine four years and only had a drive belt go once.
          Check the gear train, may be one of the gears is misaligned and causing a jam. If all rotates freely and the drive belt is ok, another thing can be the nvr, does the motor run if you depress the start button?
          Otherwise may be the speed controller board, but look for a mechanical cause first, it’s cheaper.
          #505841
          Ketan Swali
            @ketanswali79440
            Hi Mark,
            First check the guard switch to make sure it is not being triggered due to the guard not being closed properly.
            If it is not the guard switch, then disconnect machine from power supply, and check if any wires especially the ones which connect to the circuit boards have become loose, for some reason. When checking or removing boards, be careful to not touch the underside of the circuit board near the capacitors, as they do store a good level of energy, to give you a cick, if you are not careful.
            Was there any adverse jamming event which took place before you started having this issue?.
            Are you using any spray oil/fluid, which could have somehow got into the speed control pot?. There is one person I know of who had, which is why I ask.
            If the above checks fail to resolve, call and speak with Ian on Monday after 10am.
            Ketan at ARC
            #505941
            Mark Rea
              @markrea67084
              Thanks for the replies guys.
              Ketan will probably be a couple of days before i get in the workshop again, but i will follow your advice thank you.
              #506887
              Mark Rea
                @markrea67084
                Hi Ketan. I followed your advice and the problem is sorted. Thank you so much for your help and advice.
                #507036
                Meunier
                  @meunier
                  Mark, for the benefit of other Sieg SC3 users, what was the resolution ?
                  DaveD
                  #507037
                  Ketan Swali
                    @ketanswali79440
                    Posted by Meunier on 12/11/2020 16:44:10:
                    DaveD
                    Board damaged due to overload, and belt stripped. New board and belt purchased (Although it wasn't a warranty issue, supplied at subsidised price after mutual agreement)
                    Ketan at ARC.
                    Edited By Ketan Swali on 12/11/2020 16:53:23
                    #507092
                    Meunier
                      @meunier
                      Posted by Ketan Swali on 12/11/2020 16:48:48:
                      DaveD
                      Ketan at ARC.
                      Thanks for the update Ketan, good customer support as usual
                      DaveD
                      #507117
                      Ketan Swali
                        @ketanswali79440
                        DaveD
                        At present I am working from home.
                        After Ian (our Sales Manager) read my post, he called me to clarify.
                        Mark had called and discussed the problem at length with Ian and Brett. He was quite open and honest about the possibility that the damage could have taken place due to overload. Based on the discussion, both Ian and Brett decided to supply the replacement board and belt free of charge on this occasion, and Mark took their advice about working within the limitations of the machine. Ian and Brett requested Mark to keep the details of the solution confidential, as every problem is dealt with on a case by case basis. Decision taken by them for another person may be different.
                        My apologies for incorrect post.
                        Ketan at ARC.
                        Edited By Ketan Swali on 12/11/2020 21:28:03
                        #507187
                        Howard Lewis
                          @howardlewis46836
                          As always, service from Arc Euro, above and beyond!
                          No wonder they are top of my preferred supplier list, although, at my age, Ketan will never get rich on my purchases!
                          #507249
                          Meunier
                            @meunier
                            Posted by Ketan Swali on 12/11/2020 21:27:41:
                            DaveD
                            ……….to keep the details of the solution confidential, ……….
                            Ketan at ARC.
                            That's OK Ketan, I won't tell anybody else. Thanks for the correction, even better support.
                            DaveD
                            #507255
                            Ketan Swali
                              @ketanswali79440
                              Posted by Meunier on 13/11/2020 16:33:37:
                              DaveD
                              Ketan at ARC.
                              DaveD
                              smileyyes
                              #507265
                              mark costello 1
                                @markcostello1
                                Ketan, could You send some of Your Minions over here across the pond to teach service to the Companies We have here?
                                #507285
                                Ketan Swali
                                  @ketanswali79440
                                  Lol. There are times when my team and I also get it wrong, and times when we disagree with a customer. The customers who feel we have done wrong have a different opinion of our customer service.
                                  We are a small business. Companies on your side of the pond are around five times+ bigger than us, so experiences of customer service good and questionable will be more amplified.
                                  My personal experiences have been related to retail stores during a visit to New York some twelve odd years ago, where I found the people working in stores – big and small to be very helpful. During my stay there I also visited Travers where the staff were very helpful and friendly. I also meet the then owner of Victor Machinery, who showed me a paper catalogue issued by his grandfather I think, back in 1940s. He showed me around his place and introduced me to his great team. I recall being amused watching them use gum paper tape to pack cartons and thinking it was old fashioned, or possibly the American way. ARC adopted the same idea some three years ago.
                                  I also have a chat now and then with Chris Wood – LittleMachineShop. I find him and his team to be very helpful too.
                                  I did learn a few good things from my visit, as I am sure we all do from new experiences. I am sure that there must be more good companies there too.
                                  Ketan at ARC
