Semi-Steel
Semi-Steel
Home › Forums › Workshop Tools and Tooling › Semi-Steel
  • #264007
    Vic
      @vic
      I was gifted a nice Elliott chuck some years ago and using it today I noticed that apart from the Elliott name it had "Standard Semi-Steel" on the badge. Anyone know what this is? Just interested. It's a lovely 5" four jaw independent for the money. wink
      #18251
      Vic
        @vic
        #264015
          Vic,
          Others have trod this path before: **LINK**
          http://bbs.homeshopmachinist.net/threads/1478-Semi-steel-lathe-chuck
          … I doubt if it's accurately "semi" but it seems to be a good thing.
          Phil Whitley
            @philwhitley94135
            Simply put, without getting into too much detail, the only difference between cast iron and steel is the carbon content. When cast iron is made with coke in a blast furnace it absorbs a huge amount of carbon, which makes it very stable, and very hard in compression, but brittle. Mild steel is cast iron with all but a small percentage of the carbon removed, and is fairly soft. By removing some of the carbon, or diluting it by adding scrap steel to the melt, you get a very tough metal, hard, but much less brittle.
            #264326
            Ady1
              @ady1
              They used semi-steel in the main drive wheel of the Acorn Shaper
              It's meant to be tougher than cast iron
              #264352
              Brian Oldford
                @brianoldford70365
                Because of its mechanical properties I have heard SG iron referred to as semi-steel, although it hasn't much difference to grey iron in its carbon content.
