Roll Your Own…
Roll Your Own…
Home › Forums › Suggested Online Resources › Roll Your Own…
  • #635434
    Andre ROUSSEAU
      @andrerousseau66124
      Kiss Goodbye to Swarf…
      An excellent Descriptive Video:
      #21606
      Andre ROUSSEAU
        @andrerousseau66124
        Look See, It Says: “Create New Thread”!
        #635445
        David George 1
          @davidgeorge1
          I have used these rolls for making wheel axels on a capstan lathe perhaps 50 years ago. They produced a stronger thread and once set very rarely needs alteration. The rolls lasted months with continuous production runs of thousands per week.
          David
          #635454
          Clive Brown 1
            @clivebrown1
            Thread rolling was a normal production process where I worrked at Joseph Lucas back in the '60s. There were specialised machines that rolled the blanks between 2 flat die plates. These were capable of very high production rates of high quality threads.
            #635469
            Swarf, Mostly!
              @swarfmostly
              Posted by Andre ROUSSEAU on 01/03/2023 00:37:32:
              SNIP!
              Was it something I said?? wink
              Best regards,
              Swarf, Mostly!
              #635484
              Robert Atkinson 2
                @robertatkinson2
                Rolled threads are stronger and more fatique resistant than cut. This can be the difference between life and death. There have been cases of wings failing on aircraft due to cut threads. Specific cases were Tiger Moth and Stampe biplanes. See:
                https://www.atsb.gov.au/sites/default/files/media/5750718/AO-2013-226%20final.pdf
                and
                https://assets.publishing.service.gov.uk/media/5422f6c240f0b613420005a3/Stampe_SV4C_G__G-ATKC__02-88.pdf
                This second report also highlights how making the tie rod of consant diameter raather than the original waisted design increased loding on the threaded ends as the thicker, stiffer part did not share the load as well.
                Details details. Never assume you know why someone designed something a certain way unless you have a detailed description from the original designer.
                I hve a old thread rolling die on my bench. It makes a nice bench block
                Robert
                Edited By Robert Atkinson 2 on 01/03/2023 11:58:24
                Edited By Robert Atkinson 2 on 01/03/2023 12:05:38
