Repairing a 4 jaw chuck.
Home Forums Workshop Tools and Tooling Repairing a 4 jaw chuck.
  • #18023
    Brian H
      @brianh50089
      Replacing worn out hexagons in screws.
      #228867
      Brian H
        @brianh50089
        A 4 jaw chuck came with my Boxford AUD several years ago and, although I have used it a few times it was always unsatisfactory because the jaw screws were badly worn and cracked.
        I had a look for new screws only to find them in very short supply and one site that had them wanted £48 each, which is a bit pricey when you need 4 of them.
        I decided to drill and tap the screws 3/8" Whit and get some 3/8" whit capscrews.
        When they came I was delighted to find that the hexagon was exactly the same as the old ones, though without the wear and cracks.
        The capscrews were fastened in with permanent Loctite and I now have a usable chuck at a fraction of the price of new screws.
        Not for nothing are we model engineers known as tight!
        #228969
        Martin Connelly
          @martinconnelly55370
          I have a 4 jaw with cracks around what on my chuck are square recesses in the screws. The rest of the screw is in good condition so there is no problem using it at the moment. If it does start to be a problem it's nice to know there is a solution that is relatively easy and low cost. My suspicion is that the screw on chuck has been fitted or removed by a previous user using a mallet or hammer on the chuck key in the screw hole. Personally I try to avoid putting the chucks on so hard that they require impact forces to remove them.
          Martin
          #228999
          Ajohnw
            @ajohnw51620
            Some people use hex socket cap screws so that they can adjust the work with their fingers initially. Only usually seen on clock sized lathes. Also has the advantage that it's easy to get high tensile ones. Not sure about grub screws.
            Phil Whitley
              @philwhitley94135
              Excellent repair Brian, and a damned good idea!¬ Must file that away for future use!
              Phil
