Reducing round stock
Home Forums General Questions Reducing round stock
Viewing 15 posts - 1 through 15 (of 15 total)
  • #513306
    Andy Brocklehurst
      @andybrocklehurst85292
      I’ve got some 3mm 304 grade stainless steel that I need to reduce fairly accurately as it needs to be a snug fit in a reamed hardened steel 3/32 hole. The pieces only need to be 25mm long.
      I realise a lathe would be the tool for the job but I haven’t got one so I was wondering what the best method would be. Would spinning it in my mill and holding a file or sandpaper to it be accurate enough?
      Thanks
      #27823
      Andy Brocklehurst
        #513308
        Thor 🇳🇴
          @thor
          A box tool would be handy. There is also a thread on MEM.
          Thor
          Edited By Thor on 13/12/2020 19:20:13
          #513309
          Andy Brocklehurst
            Posted by Thor on 13/12/2020 19:13:44:
            Thor
            Would be handy, except I haven’t got a lathe to put one in!
            #513311
            Thor 🇳🇴
              @thor
              For such a short distance I assume you could use the same technique with your milling machine.
              Thor
              #513312
              Pete.
                @pete-2
                Put the steel in your collet chuck, then hold a cutting tool in the vice on the table, line up one axis on center, take cuts with other axis.
                #513322
                old mart
                  @oldmart
                  With that ammount of length verses diameter, you may have to work in stages, only having about 7mm projecting from the collet at a time.
                  Another way would be to clamp a block of aluminium, or brass about 30mm thick in the milling vise and drill a hole of the same diameter as the rod through it. Leave the X and Y axes stationary, and put the rod in a collet and using plenty of lubricant use the hole as a steady and reduce the diameter as the spinning rod is slowly withdrawn. Figuring out a way to hold a cutting tool is another matter.
                  It would not be much easier in a lathe because the length is 8 times the diameter.
                  Edited By old mart on 13/12/2020 20:16:49
                  #513328
                  Clive Brown 1
                    @clivebrown1
                    FWIW I'd buy some. For example MACC models have 3/32" 303 @ £0.76 p/ft. +postage.
                    #513331
                    Anonymous
                      Posted by Clive Brown 1 on 13/12/2020 21:26:23:
                      Good steer. Also 304 is a pig to machine – I hate the stuff.
                      #513333
                      Andy Brocklehurst
                        if it was only that easy, long story / process short, I have a piece of 304 ss bar that a pin is passed through and peened to the side of a knife handle, then the whole thing is polished so the pin becomes invisible, so unless it’s the same steel the pin won’t hide properly …….. hard to explain really.
                        #513336
                        Phil P
                          @philp
                          It sounds like you need a small lathe adding to your letter to Santa yes
                          Phil
                          #513351
                          John Haine
                            @johnhaine32865
                            3/32 is 2.38mm. A quick search suggests that 304 stainless is not through hardenable so are you sure you couldn't drill out the hole to 3mm and use the rod you have? Get a 3mm cobalt drill from toolstation.
                            #513359
                            Andy Brocklehurst
                              Posted by John Haine on 14/12/2020 06:55:27:
                              Correct 304 isn’t a hardening steel and drilling to 3mm would be an easy solution but the rest of the construction is set up for 3/32, it’s a faff but getting 3mm rod down to 2.38mm is the easiest route. Unless anyone can point me in the direction of 3/32 304 rod?
                              #513361
                                Would it notice if you opened the hole up to 2.5mm? If so M-machine do 2.5mm dia 304
                                #513386
                                Andy Brocklehurst
                                  Posted by JasonB on 14/12/2020 08:15:14:
                                  2.5mm might just do the trick, good shout that, didn’t realise M-Machine existed, they stock some good sizes and materials for the knife maker.
                                  Thanks
