Recommendations for where to start with my new Emco Unimat Basic SL
Home Forums Beginners questions Recommendations for where to start with my new Emco Unimat Basic SL
Viewing 25 posts - 1 through 25 (of 28 total)
  • #478385
    Lucien Anderson
      @lucienanderson84800
      Hello, I've just signed up to this site having recently purchased my first lathe.
      It's a lovely little Emco Unimat Basic SL, seems to be in good nick to my untrained eye. Any opinions on these lathes? I went for it having looked at the Sieg C0 (mixed reviews) and the Unimat 3, but this popped up on Ebay and it looked pretty smart. It really is very small, which is ideal as space in my workshop is very limited, and the lathe (for now) isn't going to be at the centre of my work.
      First bits on the list to purchase for it are HSS bits, a compound slide, quick release tool post and perhaps a 4 jaw independent chuck.
      Just wondering if anyone has any recommendations on where would be a good place to start with tooling, any starter sets that just include the basics? I'm looking to work with small bits of brass predominantly.
      Also, any basic servicing/overhauling I should be doing before I get started? Belts? Lubrication? It all looks pretty good to me, although the belts don't seem to sit perfectly centred on the gears but they're not wandering off or anything.
      I'm always looking for an excuse to tear things down and reassemble them…
      Many thanks
      #10285
      Lucien Anderson
        #478392
        Hollowpoint
          @hollowpoint
          Look for 6mm tooling rather than 1/4" inch as some will be above centre hight.
          Don't expect too much from it, its a model makers lathe.
          Belts are readily available on ebay.
          It's worth signing up to the unimat group at groups.io
          #478404
          Lucien Anderson
            Great that's helpful, I'll join that group. I'm less than a model maker so I'm sure it'll be enough for now.
            #478415
            Former Member
              @formermember32069
              #478450
              Ady1
                @ady1
                Oh dear
                My first lathe was a Unimat SL, they are hugely popular because they can be sent in the post
                Dig a hole and bury it in your back garden immediately and get a netflix subscription
                The Unimat SL is that first cigarette behind the bike sheds
                It's a trap. A taste of what you can do with a bigger machine
                Your next machine will be a bigger one you have to pick up by car
                Then you'll get another one, and then a mill, and a shaper, and a load of steel stock
                Before you know it there will be one to two tons of steel objects in your garage which have taken over your life
                Act quickly before its too late
                Edited By Ady1 on 08/06/2020 14:29:55
                #478452
                Former Member
                  @formermember32069
                  #478471
                  Lucien Anderson
                    Haha I'm well aware this is a slippery slope, although not sure how my downstairs neighbour would take to me installing a myford super 7.
                    Thanks all for your advice I'll do some more research
                    #478500
                    Brian G
                      @briang
                      There is an active group of enthusiasts on groups.io Lucien. **LINK** I'm not a very active member as I seldom use my SL any longer.
                      Original 4-jaw chucks can be expensive but Chronos or RDG tools sometimes have M12x1 chucks. The group files contain drawings for a QCTP, or there is a piston type available from the US. An alternative approach is to use multiple toolposts. I'm afraid the centre height isn't really enough for a compound slide, but you can fit a 20mm raising block which would let you use a C0 or U3 compound on a thin spacer.
                      Brian G
                      Edit: I should add that Ady is right, an SL is a real machine but can easily lead you on to a life of moving bigger and bigger machines. I thought getting a 10×30 lathe upstairs was going to be the end of me.
                      Edited By Brian G on 08/06/2020 17:45:12
                      #478507
                      Former Member
                        @formermember32069
                        #478526
                        Lucien Anderson
                          Posted by Brian G on 08/06/2020 17:35:47:
                          Brian G
                          Thanks that's really helpful, I've found this compound slide on the Emco website: *LINK*
                          There's also a QTCP on the same site: *LINK*
                          Would these not fit? The lathe looks the same?
                          Cheers
                          Lucien
                          Edited By Lucien Anderson on 08/06/2020 19:18:32
                          #478531
                          Emgee
                            @emgee
                            Hi Lucien
                            The compound slide and the QCTP are not suitable for your SL.
                            As already said there is not enough height from the cross slide to centre height for a compound unless you use a raiser block under the head, and tailstock if you want to use a centre or drill.
                            Same with any toolpost you want to fit, even with 6mm sq tooling very little packing is needed to bring the tool to centre height.
                            Best to get some HSS tooling to get started, or you may prefer to use insert type tooling, but again you have to account for the tool cutting edge to be at centre height.
                            You can use either in the std toolpost and will get you making swarf quickly.
                            I have an SL with many accessories but don't use it so often these days.
                            Emgee
                            Suitable type of insert for use with  a 6mm Tool that can be found at ARC Euro site, confirm insert shape reqd.
                            https://www.shop-apt.co.uk/carbide-tips-hobby-use/pack-of-2-ccgt-060204-alu-ak10-carbide-tips.html
                            Edited By Emgee on 08/06/2020 19:57:04
                            #478537
                            Andy Carlson
                              @andycarlson18141
                              Hi Lucien,
                              Congratulations on your SL. I hope you are very happy together. As has already been suggested, the Unimat groups.io group is well worth joining. There are folks on there who do some pretty amazing things on the SL. The group also has a lot of very useful files including the manual and info about simple projects to make on the SL.
                              Make sure the metal surfaces and particluraly the threads that move the slides are kept with a film of oil on them and most things should be OK.
                              The spindle and bearings on the SL are a 'cartridge' which can be disassembled if you are happy with getting bearings off shafts etc. I reckon mine dates from 1961 so I stripped the cartridge down when I first got it and repacked the bearings with new grease. The bearings are a standard size that can be replaced if they are worn but I could not find any detectable wear in mine so I didn't replace them. On the other hand if you are not confident about dismantling then it's probably best left alone until you are happy.
                              I'd advise HSS tooling, especially when learning the ropes. It's worth getting a bench grinder and learning to grind (and resharpen) your own tools.
                              My original plan for my own SL was to splash out on a Sherline 4 jaw chuck from Mill Hill supplies (they do one with the M12 x 1mm thread for the SL). In the end I bought another lathe… and then another… but basically the Sherline chucks seem very well regarded.
                              Having 3 different sizes of lathe myself I disagree with the 'bigger is always better' argument. A smaller lathe will give you a better 'feel' for small work. You can also put it away on a shelf when you are not using it.
                              There is occasional discussion on the groups.io group about a QCTP for the SL – an eBay seller in the US (occasionally) makes a well regarded one that fits the SL…. but TBH you should not let QCTP question hold you up – just get on and start enjoying your lathe.
                              Regards, Andy
                              #478556
                              Brian G
                                @briang
                                Double post, see below
                                Edited By Brian G on 08/06/2020 21:29:18
                                #478557
                                Brian G
                                  @briang
                                  I think we may be at cross purposes Lucien. Do you have a Unimat SL (cast bed and swivelling headstock, round bar sideways, turns into a milling machine) or a unimat basic (unimat Pc without stepper motors)?
                                  Photos here
                                  Brian G
                                  #478573
                                  Lucien Anderson
                                    Posted by Brian G on 08/06/2020 21:28:33:
                                    Photos here
                                    Brian G
                                    Yeah it's the unimat basic, the name plate says "unimat basic SL" but on lathes.co.uk it's referred to as the "Unimat PC Basic" . It's this one… *LINK*
                                    So yes I believe I've got the one without stepper motor.
                                    Still thanks all for the advice, such a wealth of knowledge on here!
                                    #478576
                                    Lucien Anderson
                                      Posted by Andy Carlson on 08/06/2020 20:22:55:
                                      Hi Lucien,
                                      Regards, Andy
                                      Thanks Andy, that's really helpful. I'll join the unimat groups.io. Reassured to hear you talk favourably about small lathes, the one I've got seems to get smaller every time I look at it.
                                      I think there might have been some confusion about which model I have, it's the Emco Unimat Basic SL, also referred to as the Emco Unimat PC Basic. But as Brian G has said, the PC version had a stepper motor, mine is the Basic and does not have a stepper motor. I think?!
                                      #478580
                                        Lucien
                                        You might find it useful to download this Parts List : **LINK**
                                        https://www.emcomachinetools.co.uk/image/catalog/pdfs/UnimatBasicspareparts.pdf
                                        … Nice to know the right numbers, if you ever need to replace anything.
                                        Andy Carlson
                                          @andycarlson18141
                                          Posted by Lucien Anderson on 08/06/2020 22:22:24:
                                          Hi Lucien,
                                          Ah OK. It probably wont be the last time then The original Unimat (before the Unimat 3) is usually known as the SL, DB or some combination of the two. Take what I said about threads etc with a pinch of salt then because I'm not au fait with the PC.
                                          Definitely no stepper motor on the 1961 model.
                                          #478682
                                          Brian G
                                            @briang
                                            I'm afraid almost everything we have told you (apart from the fact it is addictive and Michael's link to the parts list) applies to the original SL and won't be any help to you. There is some information on your machine at lathes.co.uk.
                                            As the Basic has the same M14 x 1 thread on the spindle and tailstock as the Unimat 3 and 4, you should be able to find additional chucks, drill chucks, faceplates and live centres from either Pro Machine Tools, Arc Euro Trade, Chronos, RDG Tools or eBay. If you want a collet chuck, Arc Euro Trade offer a backplate and ER collet chuck which might be a sensible alternative to the ESX chuck as you could re-use the collets on another lathe or milling machine if you get hooked.
                                            #478744
                                            Andy Carlson
                                              @andycarlson18141
                                              Yes M14 x 1 will give you many more off the shelf options. An ER16 holder and a set of collets is a very useful thing because it will get (round) work up to 10mm accurately concentric first time every time. It's also less likely to mark the thing being held.
                                              I have the Arc Euro ER16 holder on my SL but you will have an easier time because Arc do an M14 x 1 backplate so you will just need to turn the register to finished size on your machine – this means that the holder will be dialled in to your machine.
                                              Sherline do M14 x 1 chucks too… but you have a lot more options.
                                              I must admit that the PC/SL Basic had completely escaped my attention as part of the Unimat story. It looks a decent machine. Interesting that they went back to the round bar design, albeit a lot thicker than the old DB/SL.
                                              #478799
                                              clivel
                                                @clivel
                                                To my mind, the Unimat PC Basic is without a doubt the best Unimat that Emco ever made.
                                                There is absolutely no comparison between the Unimat PC Basic and the Unimat SL other than a superficial similarity due to both having round bar-beds. However, the 20mm bars of the PC Basic bed are an order of magnitude more solid than the flimsy 12mm bars of the SL bed.
                                                With its M14 x 1 spindle, the PC Basic is compatible with most Unimat 3 and 4 accessories. The exceptions being the few items that mount directly to the bed of which the only one I can think of offhand is the fixed steady, for which Emco provided one specifically for the PC Basic.
                                                The PC Basic does however also offer a significant number of advantages when compared to the 3 or 4. Not only does it have a slightly larger capacity, 54mm centre height in comparison to the 46mm of the 3 and 4, but it also includes a variable speed DC motor, automatic fine feed and screwcutting gears.
                                                I have had my Unimat PC BasIc for a number of years now, if within the budget definitely get yourself the Unimat ESX25 collet chuck along with a set of ER25 collets (they are compatible), the best investment I have made for the lathe and far more useful than ER16.
                                                I use the collet chuck for almost everything, only switching to the 4 jaw chuck for items that don't fit. As for the top slide, mine sees very little use, but you might find different
                                                The other purchase I have never regretted is the diamond tool from Eccentric Engineering who advertise on this site. Other than for some occasional boring it is essentially a permanent fixture on my lathe. It is the smallest size they carried, I think it was the T6, unfortunately they no longer seem to list it on their site.
                                                Of course, nothing is perfect, the round bars and steel frame make for an extremely rigid little machine, but aren't as convenient for placing items such as a mag base for an indicator. The motor is not very powerful and easily stalled, although for the beginner this is actually an advantage and many a time saved me from doing serious damage to the machine the workpiece or myself.
                                                And the most annoying of all is the placement of the power switches on the headstock, it is far too easy to lean on the power switch with the left hand while changing or tightening a chuck. It happened to me on more than one occasion. Partially due to the motor stalling, I was fortunate to not suffer injury or damage to the machine. To prevent this reoccurring I fitted a separate switch between the supply and the speed controller which I always make sure to turn off before changing or tightening the chuck.
                                                And even though I bought a really nice Myford ML7 a year or two back, I still enjoy using the little Unimat for the smaller stuff, and it is very convenient having a second machine setup for secondary operations.
                                                #478842
                                                Lucien Anderson
                                                  Posted by clivel on 10/06/2020 02:29:43:
                                                  Fab, good to hear you talk so favourably about this lathe. I did find people seemed to rate it highly which is why I jumped at the opportunity when one came up on ebay.
                                                  Your idea of adding a separate safety switch is inspired, I've already caught the switches a few times whilst faffing with the chuck. I'll definitely make that modification a priority.
                                                  Best,
                                                  Lucien
                                                  #480955
                                                  Lucien Anderson
                                                    OH DEAR
                                                    Tried to disassemble the headstock to clean up/re lube as it was quite stiff and I've sheared the thread on the tailstock screw spindle (part No. A4A 040 030).
                                                    Broken about 10mm off the handle end.
                                                    Any ideas where I might find a replacement?
                                                    Feeling pretty silly with myself
                                                    #480994
                                                    Andy Carlson
                                                      @andycarlson18141
                                                      Not sure about parts availability for those machines but making one might be a not too difficult alternative. Would probably need a screw cutting lathe though because it is probably a LH thread.
