ransome thrasher speed
Home Forums General Questions ransome thrasher speed
  • #511931
    tom hardy
      @tomhardy75463
      i have built a 2inch ransome thrasher with plans from blackgates what speed should the thrasher run that is the drum drive also what 12 volt electric motor would i need to run it ok the traction engine is not finished yet and i need to show off the thrasher
      tom hardy
      #27809
      tom hardy
        @tomhardy75463
        #511935
        roy entwistle
          @royentwistle24699
          A quick look on google gave me @700 rpm ( full size drum )
          #511999
          Howard Lewis
            @howardlewis46836
            To ensure that the corn is threshed properly, the reel speed needs to be fairly closely controlled. Hence a governor on the engine driving it. The exact speed would be determined by the diameter of the reel on a particular make and model of machine.
            On mechanically governed internal combustion engined combine harvesters, the engine speed was held to 5% or less from Full Load to No Load.
            Obviously in a model such precision is not needed, but some nod towards it needs to be visible,
            #512025
            Clive Foster
              @clivefoster55965
              Run it at a speed that looks right.
              Generally models run at full size speeds look frantic rather than scale.
              Slow enough to see what the wheels are doing is more interesting anyway for simple showing off. Bit different if you have something of suitable size for it to actually thrash but it would still be tweak until it works.
              #512043
              Denis O’Kane
                @denisokane59333
                Full size drum rotates between 1000 and 1100 rpm, with a beater bar speed of between 60 / 70 mph!
                Too fast for a model.
                Denis
                #512060
                tom hardy
                  @tomhardy75463
                  thanks for the replies very helpfull
                  tom
