Quartering worry
Quartering worry
Home › Forums › General Questions › Quartering worry
  • #107980
    Romeo R.L
      @romeor-l
      hello all,
      As most of you can see i am building an 08, i was quartering my axels the other day and milled a 3mm (width) slot for the key steel, one seems to be slightly off centre is this something to worry about or is it something i can correct when i set the cranks? i have not yer keyed the cranks but keyed the wheels
      #22396
      Romeo R.L
        @romeor-l
        about quartering
        #107987
        Sub Mandrel
          @submandrel
          Hi Romeo,
          I fear it might cause you problems – worst case, get the wheels set up and create a new key slot on the other side of the axle. Others with more experience than me may advise otherwise. I used a jig and loctite on my shunter.
          Romeo R.L
            @romeor-l
            Hi Neil,
            yer i think i have just enough play in the slot to set it up right, i guess i will find out if it binds or not, i might be able to make it up by playing with the con rod distances smiley or yes as you said
            Romeo
