Print a 3D Maze
Print a 3D Maze
Home Forums 3D Printers and 3D Printing Print a 3D Maze
  • #31509
      A bit of fun with a Ball Bearing
      #279302
        Here's a 3D maze I knocked up as an experiment, it would be better in opaque filament so you can't see where the 15mm ball bearing is.
        If you succeed you can reward yourself with a bottle of Glenfiddich (that's a miniature BTW!)
        You can download the STL file here.
          Amasing work Neildevil
          #279319
          jimmy b
            @jimmyb
            Good work!
            How long did it take to print and how many attempts?
            I'll have a go at printing it shortly!
            Jim
            #279333
              Worked first time, but I know the machine quite well now. It estimates 4 hrs and 40 minutes, but it was under three hours.
              What machine do you have?
              #279355
              jimmy b
                @jimmyb
                I ask, as I have been a 2 hours into a print, only to hear a strange noise, as it drags a lump of filament around the part……
                Its a "Fisher Delta" printer. I got at the show at Warwick.
                Its been a steep learning curve…..
                What are you using to create the files for printing?
                I'm using Fusion 360 and Slic3r
                Jim
                #279360
                  It should be a fairly safe print as the base is big and the walls area reasonable thickness, not much to come adrift as long as it can bridge a ~17mm gap.
                  I'm designing in Turbocad.
                  The 3D40 come with two 'preparation' programs the one I've been using is Autodesk Studio which takes an STL and outputs a 3Gdrem file which the printer prints.
