Power X Feed Problem on WM18 Mill
Home Forums Beginners questions Power X Feed Problem on WM18 Mill
  • #7977
    Martin King 2
      @martinking2
      Odd behaviour?
      #222535
      Martin King 2
        @martinking2
        Hi all,
        Yesterday I was using the mill for some light facing in aluminium and the x feed was working fine and has never beeen a problem.
        This morning when I came to do another job the unit seems to have a fault.
        The power light no longer seems to come on yet the table feed to the LHS works exactly as it should but the other way nothing happens at all.
        I have checked all fuses etc and all are good.
        I am rubbish at electrics and am loatht o get inside the unit without some good advice please.
        Regards, Martin
        #222542
        Ian Parkin
          @ianparkin39383
          Is the limit switch ok? did you mount the limit switch?
          on mine if the switch is pressed it stops travel one way yet allows you to run the other way
          Though it doesnt kill the power light
          #222550
          Martin King 2
            @martinking2
            Hi Ian, I did not fit the limit switches. Unit has been Soooooo useful and I thank you again for all your help with it.
            Problem does seem rather odd.
            Martin
            #222557
            Ian Parkin
              @ianparkin39383
              well as its not mounted where is it? is it pressed?
              #222558
              Martin King 2
                @martinking2
                Ah, Isee what you mean! Will look a bit later on and get back.
                #222645
                Martin King 2
                  @martinking2
                  Ian, Doh embarrassed, you were spot on! The switch which was hanging down the back out of the way had been nudged to on when moving something else, all OK now, many thanks! You live and learn!
                  Martin
