Polygon Turning
Polygon Turning
Home Forums General Questions Polygon Turning
  • #214460
    MW
      @mw27036
      Hi,
      Bit of a wildcard this one but does anyone know of polygon turning? ; The method used to produce accurate flats on a round bar without the aid of a mill so to speak, using a fly cutter geared to cut the bar at precise intervals.
      Has anyone tried making an attachment to try this? it would be alot of fun!
      M Walters
      #24247
      MW
        @mw27036
        just want to know if anyone knows anything about it
        #214465
        martin perman 1
          @martinperman1
          Michael,
          There are two ways of doing this but the basics are that you spin a tool at a speed relative to the round bar i.e. chuck 600 rpm, tool 100 rpm so that the tool hits the metal six times, the old method is by using gearing, the newer method is by synchronising the chuck and tool with motors and encoders. You could use a pecking unit but this is still timed via gears to the chuck.
          I've never built one but I've installed machines in companies that do the above.
          Martin P
          Edited By martin perman on 29/11/2015 09:48:44
          #214467
          Bazyle
            @bazyle
            Also known as profiling. Search for Armag profiling head. This one is unusual in having a small enough arbor to fit a home sized lathe. The shape is determined by a template (discs in top right of picture) which guide a sort of scraping tool (in the tray above the spring in the picture). Typically used for making a hole in a box for an round RF connector with a flat to stop it rotating.
            #214469
              This has been covered in one of the magazines in the past, but I can't find it in the indexes under hexagon or polygon.
              There is another method that uses a cam and follower, but IIRC the cam is not simply a hexagon
              peak4
                @peak4
                I can remember seeing an article on Tomorrow's Word donkeys years ago, which demonstrated a lathe with a geared attachment behind the headstock. The cutting tool spun as well as the workpiece and produced hexagons on the lathe. Fascinating to watch at the time.
                #214479
                peak4
                  @peak4
                  Here's a couple of uTube clips;
                  My vague memory from the past recalls something along the lines of the first one, but with a single point tool travelling 6 times faster than the workpiece.
                  Ever since I bought the Super 7 I've wondered about the feasibility of coming up with something, particularly on the Myford with a 60 tooth bull wheel, which would divide quite easily.
                  Edited By peak4 on 29/11/2015 11:08:28
                  #214484
                  Robert Dodds
                    @robertdodds43397
                    the youtube link below shows an impressive array of parts that the polygon lathe can make
                    Bob D
                    #214486
                    jason udall
                      @jasonudall57142
                      For one of our cnc..we had a macro to TURN polygons…ie with norma turning tools..it combine movement in X ( and z of course) with the spindle movement axis C…seeing this turning at 300-400 rpm was mesmerising. ..
                      Flats were pretty flat ( effected by tool setting…tnrc)
                      Machine was a Warner Swasey…lovely machine..tail stock rotated out of line as required…
                      Though that was not part of the polygon function…
