In use – when pressure is applied – the gas fills the space behind the ring and pushes the ring out against the bore. With a petrol or diesel engine or a single acting steam engine, the important face of the piston ring is the one away from the pressure – normally the underneath with a conventional layout. This means that the opposite (top) face is not critical in terms of flatness. If the rings are stamped or etched with numbers, etc, this is where they are put for this reason.
With a double-acting steam engine, both faces of the ring need to be properly flat, and the gap in the piston needs careful control as the ring is forced, every stroke, to flop across to the other side of the groove.
My thanks to Mr Ricardo (saviour of the side-valve engine) who discovered this while sitting in a WW1 tank trying to find out why it smoked so much.
Cheers, Tim
